Hi everyone
I would like to know which topic can be used to get the values for the nav2 goals that are sent through rviz2. I thought that I could use the /goal_pose but it doesnt receveived a value when using this tool.
Thanks in advance
Hi @lfernandez ,
My immediate suggestion would be to set a subscriber to /goal_pose topic.
So when you click on some place on Rviz2 and send a goal pose to /goal_pose, you can see the Pose (position + orientation) value in the subscriber.
At the moment, I assume that /goal_pose is a topic and not a service or an action.
Thanks @girishkumar.kannan. That’s what I thought but the topic /goal_pose gets nothing when you send a Nav2 goal through Rviz2. It’s strange to me.
Hi @lfernandez ,
Here is my output from /goal_pose:
user:~$ ros2 topic echo /goal_pose
header:
stamp:
sec: 1678726728
nanosec: 281811410
frame_id: map
pose:
position:
x: -0.6831712126731873
y: 0.5041952133178711
z: 0.0
orientation:
x: 0.0
y: 0.0
z: 0.050374112943495156
w: 0.998730418453927
So here is what I did:
- Make sure that the real robot or the simulation is running.
- Make sure you have
ros_bridgeenabled, if it is needed. - Make sure ROS2 nav2_stack is initialized and running, that is, map_server, amcl along with bt_navigator, planner, controller, recoveries.
- Make sure Rviz2 is up and running and make sure the robot is properly localized on Rviz2.
- Now, subscribe to
/goal_poseusing terminal or with your own program. - Issue the goal pose on Rviz2 using 2D Nav Goal button.
- Now you should see the goal pose on the
/goal_posesubscriber.
I am not sure why it is not working for you. But I am sure this method will work.
