Topics quiz, error with the code please help
so i am brushing up on my ros basics and decided to write the code for topics quiz using oop, but the problem is i keep getting the following error.
my code is as follows.
#! /usr/bin/env python3
class MoveTurtle():
    self.sub = rospy.Subscriber('/kobuki/laser/scan',LaserScan, self.callback)
    self.pub = rospy.Publisher('/cmd_vel', Twist, queue_size=1)
    self.vels = Twist()
    self.rate = rospy.Rate(2)
    self.lidar_data = LaserScan()
def callback(self, msg):
    rospy.loginfo('callback is called')
    self.lidar_data = msg
def turtle_mover(self):
        rospy.wait_for_message('/kobuki/laser/scan', LaserScan, timeout=None)
        print(self.lidar_data[359])
        if self.lidar_data[359] > 1:
            self.vels.linear.x = 0.2
            self.vels.angular.z = 0.0
            self.pub.publish(self.vels)
            rospy.loginfo('exited the loop')
        if self.lidar_data[359] < 1:
            self.vels.angular.z = 0.5  # left direction
        if self.lidar_data[0] < 1:
        if self.lidar_data[719] < 1:
            self.vels.linear.x = 0.5
            self.vels.angular.z = -0.5  # right direction
        self.rate.sleep()
if name == ‘main’:
rospy.init_node('topics_quiz_node')
mt = MoveTurtle()
rospy.loginfo('publishing into /cmd_vel topic')
mt.turtle_mover()
I think the problem is that you are trying to print the ray number 359 with print(self.lidar_data[359]) but you are not accessing properly to the ranges of the LaserScan message.
In order to access the ranges, you need to indicate as follows:
print (self.lidar_data.ranges[359])
The LaserScan message is composed of several fields, one of those is the ranges field. That is the one that contains the array of laser measurements
ah yes, i forgot to make that change, thank you for pointing it out, pretty easy to overlook smallest changes in the code. thank youu.
