I’m getting a little bit frustrating as I’ve been unable to perform this task.
I don’t understand why I can’t get the info from the callback function. Any help?
def callback(msg):
global laser_msg
laser_msg = msg
rospy.init_node('topics_quiz_node', anonymous=True)
sub = rospy.Subscriber('/kobuki/laser/scan', LaserScan, callback)
rate = rospy.Rate(2)
move = Twist()
move.linear.x = 0.5
pub.publish(move)
print(laser_msg.ranges[360])
rate.sleep()
Hi @pablotorneiro,
It seems you’re trying to access the LaserScan message outside the callback. If that is the case, you can try this instead:
def callback(msg):
# laser_msg is automatically available here because it's defined globally
# similarly, pub, move are accessible here (but move their definition before `sub`)
laser_msg = msg
laser_msg = None # define laser_msg globally, before the callback is called
move = Twist()
move.linear.x = 0.5
pub.publish(move)
if laser_msg: # it remanins None until the callback is called for the 1st time
rate.sleep()
That said, I don’t understand what you are trying to do by accessing the LaserScan message outside the callback. Consider putting your robot control logic right inside the callback:
- Any debugging of the LaserScan message (such as this print statement)
- Moving the robot (since this should depend on the LaserScan message)
Thanks for your help.
I finally managed to get to the solution according to your suggestion.
Kind regards ![:hugs: :hugs:](https://get-help.robotigniteacademy.com/images/emoji/apple/hugs.png?v=9)
