I am trying to use the tracetools_launch package that I was using from chapter 6 of the course (multithreading) but I received this error ModuleNotFoundError: No module named 'tracetools_launch'
How should I fix this error?
Hi @jeffrey.jahja7, if tracetools_launch is a package provided by the course, you should be able to fix this by simply trying your command in a different terminal. The sourcing might be mixed up in the terminal you are using.
If this is a package you created or imported into your workspace, it should be found by sourcing it, most likely in ~/catkin_ws:
Thank you @rodrigo55 !
