I am on “Unit 3: Services in ROS” and I am trying to launch a service from the “trajectory_by_name” package but I get the following error.
user:~$ roslaunch trajectory_by_name start_service.launch
[start_service.launch] is neither a launch file in package [trajectory_by_name] nor is [trajectory_by_name] a launch file name
user:~$ roscd trajectory_by_name
roscd: No such package/stack 'trajectory_by_name'
The strange thing is that I am quite positive that last time it executed without any problems. It is like the package was removed.
I’ve tried changing to another unit with another simulation and to another course to no avail.
Thank you in advance for your help.
catkin_make the catkin_ws and source devel/setup.bash, to be sure that you can find everything in the catkin_ws/src.
Type roslaunch and do the TAB-TAB to see if the suggestions have this package inside and do the same with the launch file. That will rule out the possibility that its not finding the package.
If nothing works please post here the packages so the community can debug your problem. You can aslo create a ROSject and share it here with the code you want to test using ROSDevelopementStudio
I am having the same issue in unit 3. I am stuck in unit 3 for the past 3 days. I have to move on to unit4 due to time limitations. Thanks for any help you can provide.
I followed the tutorial step by step, 3rd time:
1 rosservice list
2 rosservice info /execute_trajectory
3 roscd iri_wam_aff_demo
4 cd launch/
5 cat start_demo.launch
6 roslaunch trajectory_by_name start_service.launch
7 history | tail -
8. user:/home/simulations/public_sim_ws/src/all/iri_wam/iri_wam_aff_demo/launch$ roslaunch trajectory_by_name start_service.launch
user:/home/simulations/public_sim_ws/src/all/iri_wam/iri_wam_aff_demo/launch$ history | tail -10
This issue has been already detected and we have a fix for it. Unfortunately, we are having some problems in order to deploy the fix to Production. We are going to work to have it tomorrow on Production. I will let you know as soon as it is fixed. Sorry for the inconveniences.
This is issue has finally been solved and it should be working properly on Production. Please let me know if you still experience this issue or any other strange behavior. Sorry fhe inconveniences.
