Turtlebot2 and Turtlebot3 robot, Maze world not available
In the ROSDS simulation I couldn’t find Turtlebot2 and Turtlebot3 robot and also Maze world is not available. I am trying to run the OpenAI_ROS maze problem with Turtlebot2. Thanks
Hi @papulghosh ,
These worlds were ready-to-use in the old version of ROSDS.
But you can find them all in our public repository
https://bitbucket.org/theconstructcore/open_ai_gym_construct/src/master/
Regards
Hi @marco.nc.arruda ,
Thanks for your reply. I wanted to run the launch file that solves the turtlebot maze problem with qlearning. So which particular launch file should I here launch? I have already cloned the aforesaid bigbucket repository.
Regards
Hi @papulghosh ,
Have you seen this solution in one of our videos or posts? Please let me know which one so I can point out the correct file for you.
Regards
I tried to follow both the following tutorials:
http://wiki.ros.org/openai_ros/TurtleBot2%20with%20openai_ros
But it seems like the repos are old and updated later, so throwing some errors.
Hi @papulghosh ,
Could you share the rosject you are working with so I can check the errors being thrown?
The repo could be outdated indeed, but it runs with the specific distro presented in the video
