Tutorial Code Modification Suggestion - ROS2 Basics in 5 Days - Python
Hi The Construct Team,
I noticed a few things missing in the code provided in the tutorial for Chapter 5 - ROS2 Actions.
I am providing my modification suggestions.
Original code in tutorial:
5.3 Action Server
import rclpy
from rclpy.action import ActionServer
from rclpy.node import Node
from t3_action_msg.action import Move
import time
class MyActionServer(Node):
        super().__init__('my_action_server')
        self._action_server = ActionServer(self, Move, 'turtlebot3_as_2',self.execute_callback)
        self.cmd = Twist()
    def execute_callback(self, goal_handle):
        self.get_logger().info('Executing goal...')
        feedback_msg = Move.Feedback()
        feedback_msg.feedback = "Moving to the left left left..."
        for i in range(1, goal_handle.request.secs):
            self.get_logger().info('Feedback: '.format(feedback_msg.feedback))
            goal_handle.publish_feedback(feedback_msg)
            self.cmd.linear.x = 0.3
            self.cmd.angular.z =0.3
            time.sleep(1)
        goal_handle.succeed()
        self.cmd.linear.x = 0.0
        self.cmd.angular.z = 0.0
        result = Move.Result()
        result.status = "Finished action server. Robot moved during 5 seconds"
        return result
def main(args=None):
    rclpy.init(args=args)
    my_action_server = MyActionServer()
    rclpy.spin(my_action_server)
if __name__ == '__main__':
    main()
My modification suggestion:
import rclpy
import time
            self, Move, 'turtlebot3_as_2', self.execute_callback)
        self.cmd = Twist()
                'Feedback: {0}'.format(feedback_msg.feedback))
            self.cmd.angular.z = 0.3
            time.sleep(1)
            'Result: {0}'.format(result.status))
        return result
    main()
Differences:
Thanks,
Another minor modification suggestion in Chapter 4 - ROS2 Services.
4.3 Service Client
# import the empty module from std_servs Service interface
from std_srvs.srv import Empty
# import the ROS2 Python client libraries
import rclpy
class ClientAsync(Node):
        # Here you have the class constructor
        # call the class constructor to initialize the node as service_client
        super().__init__('service_client')
        # create the Service Client object
        # defines the name and type of the Service Server you will work with.
        self.client = self.create_client(Empty, 'moving')
        # checks once per second if a Service matching the type and name of the Client is available.
        while not self.client.wait_for_service(timeout_sec=1.0):
            # if it is not available, a message is displayed
            self.get_logger().info('service not available, waiting again...')
        # create an Empty request
        self.req = Empty.Request()
    def send_request(self):
        # send the request
        self.future = self.client.call_async(self.req)
    client = ClientAsync()
    # run the send_request() method
    client.send_request()
    while rclpy.ok():
        rclpy.spin_once(client)
        if client.future.done():
            try:
                # checks the future for a response from the Service
                # while the system is running.
                # If the Service has sent a response, the result will be written
                # to a log message.
                response = client.future.result()
            except for Exception as e:
                # Display the message on the console
                client.get_logger().info(
                    'Service call failed %r' % (e,))
            else:
                    'the robot is moving' )
            break
    client.destroy_node()
    rclpy.shutdown()
    main()
My modification suggestion: (minor change only)
import rclpy
        # send the request
    while rclpy.ok():
            try:
                # to a log message.
            except Exception as e:
            else:
            break
    rclpy.shutdown()
    main()
Differences:
Thanks,
@girishkumar.kannan
Thank you so much for pointing out these bugs. I have corrected them; the corrections will be live in the next hr.
