I have made a booking for turtlebot3. In the bottom of the rosject it shows time remaining. But when I press turn on, I get the error “Are you sure you have a booking for now? If so, please try again in a few seconds.”
Thank you for letting us know about this issue. I will try to reproduce your error working with the frontend team
Hi, I just checked the booking records and it seems like you reserved for February 8th at 14:30 CET, which hasn’t happened yet. Is this correct?
I just noticed that my laptop clock was out of sync hence I made the wrong booking and got confused with the timing.
To solve this simply fix the timing on your laptop clock.
Yes thanks, I noticed the problem was with my clock.
