Unable to Connect to Real Robot
Here is the error from the linux terminal
user:~$ roslaunch turtlebot3_teleop turtlebot3_teleop_key.launch
… logging to /home/user/.ros/log/805a80ac-3f6d-11ef-af0b-0242ac180002/roslaunch-3_xterm-2357.log
Press Ctrl-C to interrupt
started roslaunch server http://3_xterm:39801/
SUMMARY
PARAMETERS
  • /model: burger
  • /rosdistro: noetic
  • /rosversion: 1.15.11
NODES
turtlebot3_teleop_keyboard (turtlebot3_teleop/turtlebot3_teleop_key)
RLException: ERROR: unable to contact ROS master at [http://master:11311]
Hi @nazibchowdhury000,
Thanks for reporting the error.
We will investigate this issue and come back to you.
Hi again, @nazibchowdhury000,
We are now detecting when this problem happens.
When it happens, you should now see a yellow badge with instructions to disconnect and connect to the robot again, like in the image below.
Thank you very much for reporting the issue, because it allowed us to investigate the issue a bit deeper.
#KeepPushingYourROSLearning
robot-disconnected
