Are you sure that you are using the correct keys to move the robot and not getting confused with the keys?
u | i | o # <--- i = move front
j | k | l # <--- j = left, k = stop, l = right
m | , | . # <--- , = move back
q / w / e # <--- linear & angular / linear / angular speed increase
z / x / c # <--- linear & angular / linear / angular speed decrease
Let us know if this is what you did and you still had issues with the robot.
Also, keep in mind that the terminal where you are running the teleop program must have the focus (click on it to be sure) before you can use the keyboard to control the robot.
Thanks @girishkumar.kannan , it works.
I initially used the q/w/e keys instead of the i/j/k/l, as I’m accustomed to the w/a/s/d configuration commonly used for movement in PC games. This led to confusion due to the unusual key mapping.
