Unable to create action message
Hi !
I am unable to create a Action message for final quiz . I have followed the whole procedue 3-4 time but still its not create the action messge. I have added the cmakelists and package code below.
Cmake lists :
project(actions_quiz)
Compile as C++11, supported in ROS Kinetic and newer
add_compile_options(-std=c++11)
Find catkin macros and libraries
if COMPONENTS list like find_package(catkin REQUIRED COMPONENTS xyz)
is used, also find other catkin packages
actionlib_msgs
std_msgs
System dependencies are found with CMake’s conventions
find_package(Boost REQUIRED COMPONENTS system)
Uncomment this if the package has a setup.py. This macro ensures
modules and global scripts declared therein get installed
See http://ros.org/doc/api/catkin/html/user_guide/setup_dot_py.html
catkin_python_setup()
Declare ROS messages, services and actions
To declare and build messages, services or actions from within this
package, follow these steps:
* Let MSG_DEP_SET be the set of packages whose message types you use in
your messages/services/actions (e.g. std_msgs, actionlib_msgs, …).
* In the file package.xml:
* add a build_depend tag for “message_generation”
* add a build_depend and a exec_depend tag for each package in MSG_DEP_SET
* If MSG_DEP_SET isn’t empty the following dependency has been pulled in
but can be declared for certainty nonetheless:
* add a exec_depend tag for “message_runtime”
* In this file (CMakeLists.txt):
* add “message_generation” and every package in MSG_DEP_SET to
find_package(catkin REQUIRED COMPONENTS …)
* add “message_runtime” and every package in MSG_DEP_SET to
catkin_package(CATKIN_DEPENDS …)
* uncomment the add_*_files sections below as needed
and list every .msg/.srv/.action file to be processed
* uncomment the generate_messages entry below
* add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES …)
Generate messages in the ‘msg’ folder
add_message_files(
FILES
Message1.msg
Message2.msg
Generate services in the ‘srv’ folder
add_service_files(
FILES
Service1.srv
Service2.srv
Generate actions in the ‘action’ folder
add_action_files(
FILES
CustomActionMsg.action
Generate added messages and services with any dependencies listed here
generate_messages(
DEPENDENCIES
actionlib_msgs std_msgs
Declare ROS dynamic reconfigure parameters
To declare and build dynamic reconfigure parameters within this
* add a build_depend and a exec_depend tag for “dynamic_reconfigure”
* add “dynamic_reconfigure” to
* uncomment the “generate_dynamic_reconfigure_options” section below
and list every .cfg file to be processed
Generate dynamic reconfigure parameters in the ‘cfg’ folder
generate_dynamic_reconfigure_options(
cfg/DynReconf1.cfg
cfg/DynReconf2.cfg
catkin specific configuration
The catkin_package macro generates cmake config files for your package
Declare things to be passed to dependent projects
INCLUDE_DIRS: uncomment this if your package contains header files
LIBRARIES: libraries you create in this project that dependent projects also need
CATKIN_DEPENDS: catkin_packages dependent projects also need
DEPENDS: system dependencies of this project that dependent projects also need
catkin_package(
INCLUDE_DIRS include
LIBRARIES actions_quiz
CATKIN_DEPENDS actionlib_msgs std_msgs
DEPENDS system_lib
Build
Specify additional locations of header files
Your package locations should be listed before other locations
include_directories(
include
${catkin_INCLUDE_DIRS}
Declare a C++ library
add_library(${PROJECT_NAME}
src/${PROJECT_NAME}/actions_quiz.cpp
Add cmake target dependencies of the library
as an example, code may need to be generated before libraries
either from message generation or dynamic reconfigure
add_dependencies(${PROJECT_NAME} ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
Declare a C++ executable
With catkin_make all packages are built within a single CMake context
The recommended prefix ensures that target names across packages don’t collide
add_executable(${PROJECT_NAME}_node src/actions_quiz_node.cpp)
Rename C++ executable without prefix
The above recommended prefix causes long target names, the following renames the
target back to the shorter version for ease of user use
e.g. “rosrun someones_pkg node” instead of “rosrun someones_pkg someones_pkg_node”
set_target_properties(${PROJECT_NAME}_node PROPERTIES OUTPUT_NAME node PREFIX “”)
Add cmake target dependencies of the executable
same as for the library above
add_dependencies(${PROJECT_NAME}_node ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
Specify libraries to link a library or executable target against
target_link_libraries(${PROJECT_NAME}_node
${catkin_LIBRARIES}
Install
all install targets should use catkin DESTINATION variables
See http://ros.org/doc/api/catkin/html/adv_user_guide/variables.html
Mark executable scripts (Python etc.) for installation
in contrast to setup.py, you can choose the destination
catkin_install_python(PROGRAMS
scripts/my_python_script
DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
Mark executables for installation
See http://docs.ros.org/melodic/api/catkin/html/howto/format1/building_executables.html
install(TARGETS ${PROJECT_NAME}_node
RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
Mark libraries for installation
See http://docs.ros.org/melodic/api/catkin/html/howto/format1/building_libraries.html
ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
RUNTIME DESTINATION ${CATKIN_GLOBAL_BIN_DESTINATION}
Mark cpp header files for installation
install(DIRECTORY include/${PROJECT_NAME}/
DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
FILES_MATCHING PATTERN “*.h”
PATTERN “.svn” EXCLUDE
Mark other files for installation (e.g. launch and bag files, etc.)
install(FILES
# myfile1
# myfile2
DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
Testing
Add gtest based cpp test target and link libraries
catkin_add_gtest(${PROJECT_NAME}-test test/test_actions_quiz.cpp)
if(TARGET ${PROJECT_NAME}-test)
target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME})
endif()
Add folders to be run by python nosetests
catkin_add_nosetests(test)
package.xml
<?xml version="1.0"?>
actions_quiz
0.0.0
The actions_quiz package
user
TODO
<build_depend>actionlib_msgs</build_depend>
<build_export_depend>actionlib_msgs</build_export_depend>
<exec_depend>actionlib_msgs</exec_depend>
@muhammadjunaid
What you have posted here is totally unreadable. But you don’t need to post the codes here.
Please go over the instructions again. If you have created custom messages in the exercises before the quiz, and you should have, you need to just follow the same procedure to create the one for the quiz taking note of the differences in the names.
Now when you say the action message was not created, how do you know that? What commands have you run to check?
After following all the instructions , when did these instruction it did not output the my custom message :
roscd; cd …
catkin_make
source devel/setup.bash
rosmsg list | grep Name
I was confused , but after deleting build folder and rerunning the procedure it worked :+1:
