Hi, I am unable to enter any commands. If someone could let me know and how I can fix this. I did the incorrect step here and now I can’t move forward. Thank you!
What exactly did you do to generate this issue?
In theory refreshing the page could fix that issue
Hi @celenemeraz ,
I suppose you opened the file using vi / vim.
Remember that in order to be able to insert code using vim, you have to enable the INSERT mode by pressing the “i” key.
Just try the following:
- Click the web shell to give it focus
- Open the file using vi
- pres “i” to enable INSERT mode.
- Start inserting whatever code you ant
To exit from vim , just press ESC, then “:q!” if you don’t want to save any changes, or “:x” if you want to save the changes.
Please let us know if you face any other problems.
Thank you very much. I refreshed it as I couldn’t figure out what was wrong.
Thank you very much! I will follow this next time. Thanks again!
