Hi @karthiaru ,
I think the rosject environment is lacking the installation of rqt_tf_tree
package.
Your error clearly explains that when the output says: Package 'xyz' not found
Run the following commands to install the package:
cd ~
sudo apt update
sudo apt install ros-<distro>-rqt-tf-tree # distro=humble [in your case]
depends on ros-<distro>-rqt-gui
package to also be installed.
In case rqt_tf_tree
does not start, then you may have to install rqt_gui
package also.
In that case, also install rqt_gui
package:
cd ~
sudo apt update
sudo apt install ros-<distro>-rqt-gui
sudo apt install ros-<distro>-rqt-gui-cpp ros-<distro>-rqt-gui-py
This should fix your problem.
Regards,
Girish
