Hi, I’m getting a undefined reference to ros::init error in my main function. I think I’ve included all the necessary dependencies in CMakeLists.txt . May I know why?
Hey Brian,
It’s hard to tell since you didn’t share your CMakeLists.txt.
Anyways, I see that this error is not just about ros::init but anything ros::, so could you please check that roscpp was added as a dependency? If so, you should see that in your CMakeLists.txt and package.xml, which should contain the following lines:
# CMakeLists.txt. Should be on line 10 or so
roscpp
<!-- package.xml. Should contain these lines -->
<build_depend>roscpp</build_depend>
<build_export_depend>roscpp</build_export_depend>
<exec_depend>roscpp</exec_depend>
If this is already the case, try removing the build and devel folder and running catkin_make again.
user:~/catkin_ws$ rm -rf devel/ build/
user:~/catkin_ws$ catkin_make
project(topics_quiz)
message_generation
roscpp
sensor_msgs
std_msgs
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
# generate_messages(
# DEPENDENCIES
# sensor_msgs# std_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES topics_quiz
# CATKIN_DEPENDS message_generation roscpp sensor_msgs std_msgs
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/topics_quiz.cpp
## Declare a C++ executable
add_executable(topics_quiz_publisher src/topics_quiz_publisher.cpp)
add_dependencies(topics_quiz_publisher ${topics_quiz_publisher_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
# ${catkin_LIBRARIES}
## Install ##
# install(PROGRAMS
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_topics_quiz.cpp)
# endif()
# catkin_add_nosetests(test)
this is my current cmakelists.txt.
Edit: I see the errors now in target_link_libraries. Thanks!
Great! So the problem was that this line was missing in CMakeLists.txt.
target_link_libraries(quiz_node ${catkin_LIBRARIES})
