Understanding how values from a subscribed topic are stored in an array
Hello, I am working on the code of section 3 of the ROS2 in 5 Days Python course.
I managed to make the action server run and return the odometry values after one lap.
However, I am having a difficulty understanding why the feedback message current_total, that should show the updated distance travelled, was not being updated. I managed to make it work but I don’t understand why changing the position of time.sleep(1.0) would make any difference. First of all, below you can find the whole code of the action server that is running without any problem ( with the self.total_distance variable is being successfully updated in each loop):
import time
import rclpy
from rclpy.action import ActionServer
from rclpy.node import Node
from rclpy.callback_groups import ReentrantCallbackGroup
from rclpy.qos import ReliabilityPolicy, DurabilityPolicy, QoSProfile
from custom_interface.action import OdomRecord
from geometry_msgs.msg import Point
class OdomRecActionServer(Node):
        super().__init__('odom_rec_action_server')
        self.action_cbg = ReentrantCallbackGroup()
        self.sub_cbg = self.action_cbg
        self._action_server = ActionServer(
            self, OdomRecord, 'record_odom', self.execute_callback, callback_group=self.action_cbg)
        self.odom_subscriber = self.create_subscription(
            Odometry,
            '/odom',
            self.odom_callback,
            QoSProfile(depth=10, reliability=ReliabilityPolicy.BEST_EFFORT,
                       durability=DurabilityPolicy.VOLATILE),
            callback_group=self.sub_cbg)
        # variable used to store the current odometry message in odom_callback() (continuously updated)
        self.last_odom = Point()
        # variable used to store the initial odometry message in execute_callback() (NOT updated)
        self.first_odom = Point()
        # declaring variable used to store an array of odometry messages
        self.odom_record = []
        # variable used to store the updated distance travelled during the Actionc callback
        self.total_distance = 0.0
        # variables used to store the current x position for the feedback message
        self.last_x = 0.0
        # variables used to store the current y position for the feedback message
        self.last_y = 0.0
    def execute_callback(self, goal_handle):
        self.get_logger().info('Executing goal...')
        # creating the feedback message variable
        feedback_msg = OdomRecord.Feedback()
        feedback_msg.current_total = 0.0
        # ensuring all variables that will be used below are reset
        self.last_x = 0.0
        self.last_y = 0.0
        # storing the first odometry values received (to be used as a reference later)
        self.first_odom.x = self.last_odom.x
        self.first_odom.y = self.last_odom.y
        # iteration variable will be used to ensure that action server doesn't stop prematurely
        iter = 0
        while True:
            # incrementing the number of iteration
            iter += 1
            # store current odometry measurement in an array of Point values (IN WHILE LOOP)
            self.odom_record.append(self.last_odom)
            # waiting 1 second before repeating the loop
            # time.sleep(1.0)
            # taking the last odometry measurment stored in the odom_record array
            self.last_x = self.odom_record[-1].x
            self.last_y = self.odom_record[-1].y
            time.sleep(1.0)
            # DEBUGGING CODE
            self.get_logger().warn(f'last_x= {self.last_x}')
            self.get_logger().warn(f'last_odom_x= {self.last_odom.x}')
            self.get_logger().warn(f'last_y= {self.last_y}')
            self.get_logger().warn(f'last_odom_y= {self.last_odom.y}')
            # computing the distance travelled so far (IN WHILE LOOP)
            self.total_distance = self.total_distance + self.dist_diff([self.last_x, self.last_y],
        [self.last_odom.x, self.last_odom.y])
            # Return as feedback the current value of self.total_distance (IN WHILE LOOP)
            feedback_msg.current_total = self.total_distance
            goal_handle.publish_feedback(feedback_msg)
            # calculating the distance between the initial measurement and the current measurement
            self.first_last_dist = self.dist_diff([self.last_odom.x, self.last_odom.y], [
                                                  self.first_odom.x, self.first_odom.y])
                f"DISTANCE TO INITIAL POSITION= {self.first_last_dist}")
            self.get_logger().warn(f'TOTAL DISTANCE= {self.total_distance}')
            # check if initial position is reached again (iter>5 was added to ensure that the while loop doesn't end prematurely)
            if self.first_last_dist < 0.05 and iter > 5:
                self.get_logger().warn("INITIAL POSITION REACHED!")
                break
        # updating the goal_handle state to SUCCEED
        goal_handle.succeed()
        # returning the total list of odometry measurements
        result = OdomRecord.Result()
        result.list_of_odoms = self.odom_record
            f'The list of odometry measurement is: {result.list_of_odoms}')
        return result
    def dist_diff(self, a, b):
        return ((a[0]-b[0])**2 + (a[1]-b[1])**2)**0.5
    def odom_callback(self, msg):
        self.last_odom.x = msg.pose.pose.position.x
        self.last_odom.y = msg.pose.pose.position.y
def main(args=None):
    rclpy.init(args=args)
    odom_record_server = OdomRecActionServer()
    # Create a MultiThreadedExecutor
    executor = MultiThreadedExecutor(num_threads=4)
    # adding node to executor
    executor.add_node(odom_record_server)
    try:
        # spin the executor
        executor.spin()
    finally:
        executor.shutdown()
        odom_record_server.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
    main()
An example output of the action server code above is:
user:~/ros2_ws$ ros2 run wall_follower odometry_recording
[INFO] [1677542142.680029059] [odom_rec_action_server]: Executing goal...
[WARN] [1677542143.682676880] [odom_rec_action_server]: last_x= -0.6726208989146514
[WARN] [1677542143.684019978] [odom_rec_action_server]: last_odom_x= -0.6782458260208939
[WARN] [1677542143.685634685] [odom_rec_action_server]: last_y= -0.005471049945289023
[WARN] [1677542143.686940758] [odom_rec_action_server]: last_odom_y= -0.05591538678318488
[INFO] [1677542143.688691758] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.05075697906658393
[WARN] [1677542143.689649770] [odom_rec_action_server]: TOTAL DISTANCE= 0.05075697906658393
[WARN] [1677542144.743639571] [odom_rec_action_server]: last_x= -0.6782458260208939
[WARN] [1677542144.744663257] [odom_rec_action_server]: last_odom_x= -0.6854872295965918
[WARN] [1677542144.745574416] [odom_rec_action_server]: last_y= -0.05591538678318488
[WARN] [1677542144.747110056] [odom_rec_action_server]: last_odom_y= -0.11875939360816222
[INFO] [1677542144.750488593] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.11401662718697787
[WARN] [1677542144.751451130] [odom_rec_action_server]: TOTAL DISTANCE= 0.11401681719128931
[WARN] [1677542145.755498129] [odom_rec_action_server]: last_x= -0.6858646325452228
[WARN] [1677542145.757089662] [odom_rec_action_server]: last_odom_x= -0.6932108318615994
[WARN] [1677542145.758061295] [odom_rec_action_server]: last_y= -0.12204490204340702
[WARN] [1677542145.759114212] [odom_rec_action_server]: last_odom_y= -0.1846577651779565
[INFO] [1677542145.764101743] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.18036580677787264
[WARN] [1677542145.765368661] [odom_rec_action_server]: TOTAL DISTANCE= 0.17705916228014018
[WARN] [1677542146.767275405] [odom_rec_action_server]: last_x= -0.6936142100484254
[WARN] [1677542146.768088894] [odom_rec_action_server]: last_odom_x= -0.7003341625677505
[WARN] [1677542146.768774104] [odom_rec_action_server]: last_y= -0.18802165000832768
[WARN] [1677542146.769409807] [odom_rec_action_server]: last_odom_y= -0.2442640375504716
[INFO] [1677542146.770327432] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.2403957485308654
[WARN] [1677542146.772358849] [odom_rec_action_server]: TOTAL DISTANCE= 0.23370158382356193
[WARN] [1677542147.773864813] [odom_rec_action_server]: last_x= -0.7003341625677505
[WARN] [1677542147.774726841] [odom_rec_action_server]: last_odom_x= -0.7088579512904147
[WARN] [1677542147.775295985] [odom_rec_action_server]: last_y= -0.2442640375504716
[WARN] [1677542147.775939050] [odom_rec_action_server]: last_odom_y= -0.31336493297064044
[INFO] [1677542147.776589871] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.3100189787243881
[WARN] [1677542147.777148386] [odom_rec_action_server]: TOTAL DISTANCE= 0.3033262110904833
[WARN] [1677542148.779990334] [odom_rec_action_server]: last_x= -0.7088579512904147
[WARN] [1677542148.780702700] [odom_rec_action_server]: last_odom_x= -0.7162730189917992
[WARN] [1677542148.781630045] [odom_rec_action_server]: last_y= -0.31336493297064044
[WARN] [1677542148.782457153] [odom_rec_action_server]: last_odom_y= -0.37273631540122176
[INFO] [1677542148.783304930] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.3698503518960696
[WARN] [1677542148.784117876] [odom_rec_action_server]: TOTAL DISTANCE= 0.3631588466728681
[WARN] [1677542149.843405040] [odom_rec_action_server]: last_x= -0.7162730189917992
[WARN] [1677542149.845916246] [odom_rec_action_server]: last_odom_x= -0.7234921270999027
[WARN] [1677542149.846949589] [odom_rec_action_server]: last_y= -0.37273631540122176
[WARN] [1677542149.848319269] [odom_rec_action_server]: last_odom_y= -0.4321481234285962
[INFO] [1677542149.849860272] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.4297489851025187
[WARN] [1677542149.851281749] [odom_rec_action_server]: TOTAL DISTANCE= 0.4230598490608686
[WARN] [1677542150.853366177] [odom_rec_action_server]: last_x= -0.7239128589119578
[WARN] [1677542150.854216207] [odom_rec_action_server]: last_odom_x= -0.7321036986772314
[WARN] [1677542150.855059434] [odom_rec_action_server]: last_y= -0.4321481234285962
[WARN] [1677542150.855906459] [odom_rec_action_server]: last_odom_y= -0.4947409855985233
[INFO] [1677542150.858320416] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.49287247174265597
[WARN] [1677542150.859902941] [odom_rec_action_server]: TOTAL DISTANCE= 0.486186358949218
[WARN] [1677542151.861502007] [odom_rec_action_server]: last_x= -0.7321036986772314
[WARN] [1677542151.862484768] [odom_rec_action_server]: last_odom_x= -0.7383394251759293
[WARN] [1677542151.863722489] [odom_rec_action_server]: last_y= -0.4947409855985233
[WARN] [1677542151.864752795] [odom_rec_action_server]: last_odom_y= -0.5480838666223671
[INFO] [1677542151.865673514] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.5465780763223006
However, I was having a problem when time.sleep(1.0) is uncommented just after appending the current odometry value to the self.odom_record array, as shown below. In this case, the total_distance variable would not get updated.
while True:
            iter += 1
            time.sleep(1.0)
            # time.sleep(1.0)
            # DEBUGGING CODE
And the output message coming from the action server in this case would be:
[INFO] [1677541290.174260067] [odom_rec_action_server]: Executing goal...
[WARN] [1677541291.177609647] [odom_rec_action_server]: last_x= 0.4794518750645817
[WARN] [1677541291.178560632] [odom_rec_action_server]: last_odom_x= 0.4794518750645817
[WARN] [1677541291.179550269] [odom_rec_action_server]: last_y= 0.57807118235036
[WARN] [1677541291.180583174] [odom_rec_action_server]: last_odom_y= 0.57807118235036
[INFO] [1677541291.181561718] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.052386824684167214
[WARN] [1677541291.182749057] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[WARN] [1677541292.187788291] [odom_rec_action_server]: last_x= 0.42584469004918685
[WARN] [1677541292.188857163] [odom_rec_action_server]: last_odom_x= 0.42584469004918685
[WARN] [1677541292.189895429] [odom_rec_action_server]: last_y= 0.6043207953602485
[WARN] [1677541292.191020197] [odom_rec_action_server]: last_odom_y= 0.6043207953602485
[INFO] [1677541292.192101484] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.11206327548787373
[WARN] [1677541292.193148400] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[WARN] [1677541293.197031827] [odom_rec_action_server]: last_x= 0.3751443507044991
[WARN] [1677541293.197949521] [odom_rec_action_server]: last_odom_x= 0.3751443507044991
[WARN] [1677541293.198882016] [odom_rec_action_server]: last_y= 0.6291292805008104
[WARN] [1677541293.243135607] [odom_rec_action_server]: last_odom_y= 0.6291292805008104
[INFO] [1677541293.244259209] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.16850427726454678
[WARN] [1677541293.245197671] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[WARN] [1677541294.250472737] [odom_rec_action_server]: last_x= 0.3360427235019496
[WARN] [1677541294.251380302] [odom_rec_action_server]: last_odom_x= 0.3360427235019496
[WARN] [1677541294.252882512] [odom_rec_action_server]: last_y= 0.6467394970644721
[WARN] [1677541294.253723770] [odom_rec_action_server]: last_odom_y= 0.6467394970644721
[INFO] [1677541294.254608342] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.21137963584037903
[WARN] [1677541294.256587080] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[WARN] [1677541295.260006257] [odom_rec_action_server]: last_x= 0.2758662231249633
[WARN] [1677541295.261110346] [odom_rec_action_server]: last_odom_x= 0.2758662231249633
[WARN] [1677541295.262126842] [odom_rec_action_server]: last_y= 0.664353171040243
[WARN] [1677541295.269069133] [odom_rec_action_server]: last_odom_y= 0.664353171040243
[INFO] [1677541295.274211619] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.27348875541996887
[WARN] [1677541295.275473234] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[WARN] [1677541296.280095787] [odom_rec_action_server]: last_x= 0.21176779545284313
[WARN] [1677541296.281527472] [odom_rec_action_server]: last_odom_x= 0.21176779545284313
[WARN] [1677541296.283060991] [odom_rec_action_server]: last_y= 0.6773592530578566
[WARN] [1677541296.284254196] [odom_rec_action_server]: last_odom_y= 0.6773592530578566
[INFO] [1677541296.285222494] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.33778236778012233
[WARN] [1677541296.286330123] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[WARN] [1677541297.291306712] [odom_rec_action_server]: last_x= 0.15981497577903334
[WARN] [1677541297.292156922] [odom_rec_action_server]: last_odom_x= 0.15981497577903334
[WARN] [1677541297.292967509] [odom_rec_action_server]: last_y= 0.6817164950071584
[WARN] [1677541297.293770558] [odom_rec_action_server]: last_odom_y= 0.6817164950071584
[INFO] [1677541297.294786832] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.3881245862126242
[WARN] [1677541297.295653759] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[WARN] [1677541298.297791043] [odom_rec_action_server]: last_x= 0.10111418690491109
[WARN] [1677541298.347995525] [odom_rec_action_server]: last_odom_x= 0.10111418690491109
[WARN] [1677541298.349073971] [odom_rec_action_server]: last_y= 0.6800319826982555
[WARN] [1677541298.350081239] [odom_rec_action_server]: last_odom_y= 0.6800319826982555
[INFO] [1677541298.352178493] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.4436161928511153
[WARN] [1677541298.358890878] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[WARN] [1677541299.361411285] [odom_rec_action_server]: last_x= 0.0428699295252698
[WARN] [1677541299.362339448] [odom_rec_action_server]: last_odom_x= 0.0428699295252698
[WARN] [1677541299.381338605] [odom_rec_action_server]: last_y= 0.6714783661723073
[WARN] [1677541299.412316286] [odom_rec_action_server]: last_odom_y= 0.6708092025689542
[INFO] [1677541299.413566589] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.5006727061408018
[WARN] [1677541299.417207248] [odom_rec_action_server]: TOTAL DISTANCE= 0.003208540194815803
[WARN] [1677541300.443477337] [odom_rec_action_server]: last_x= -0.013942754725924844
[WARN] [1677541300.445374861] [odom_rec_action_server]: last_odom_x= -0.013942754725924844
[WARN] [1677541300.447539358] [odom_rec_action_server]: last_y= 0.6559830908993256
[WARN] [1677541300.449335970] [odom_rec_action_server]: last_odom_y= 0.6559830908993256
[INFO] [1677541300.451842796] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.5501901124997405
[WARN] [1677541300.454085836] [odom_rec_action_server]: TOTAL DISTANCE= 0.003208540194815803
[WARN] [1677541301.458055579] [odom_rec_action_server]: last_x= -0.07100828279412819
[WARN] [1677541301.459001430] [odom_rec_action_server]: last_odom_x= -0.07100828279412819
[WARN] [1677541301.459814731] [odom_rec_action_server]: last_y= 0.632506548078621
[WARN] [1677541301.460624726] [odom_rec_action_server]: last_odom_y= 0.632506548078621
[INFO] [1677541301.462801560] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.6029935646591323
Can someone tell me why does this happen ? I thought that the position of time.sleep(1.0) whether it
is added before or after updating the values of self.last_x and self.last_y wouldn’t make any difference, since in any case, self.last_x and self.last_y are updated from the last value stored in the self.odom_record array.
Thank you for your help.
Hi @e.na.hatem
Could you shared your action_client too?
To debug and see what I can do
What could explain this is the fact of using multi-threading. Chances are that by giving it a time between the code, you can make it jump by time. When multi-threading, you usually don’t know which part will start first, since it’s not up to you.
Usually I put the time at the end of the whole and I think that it’s a recomendation , but it seems that it found a place inside where it could also work.
This would be all from me
Regardish
Ruben
Hi @e.na.hatem ,
Your action client program has nothing to do with the functioning of your action server - so please remove it from the post. Action client just calls the Action server to execute the goal. Action client has no control over the action server, once the goal is sent (of course, the only other control the client has would be to cancel the goal, so technically action client has no control over the server).
I think I see what your problem is with current_total not getting updated.
You are actually getting the distance between the same points in your while loop - thus you are getting 0.0 everytime.
Let me explain:
# you take the current odom value
# then you take the previous value from the array
# the above two values are same as the current value that you appended to the array
# then you calculate distance
# at this point in your code, the values contained by self.last_odom is same as self.last_x and self.last_y
# so you are actually calculating the distance between two points and you are accidentally calculating distance between two points where the two points are the same values.
# naturally you will get 0.0 as distance measure!
Your fix is very simple. Once you have appended the current odom value to the array, get the last value and the second to last value to calculate the distance.
Pseudocode:
1. append current odom value
2. curr_odom = self.odom_record[-1]
3. prev_odom = self.odom_record[-2]
4. distance = calculate_distance(curr_odom, prev_odom)
5. update distance measure into self.total_distance
6. update distance measure into feedback_msg.current_total
Regarding time.sleep():
  1. When you have time.sleep() between “append current odometry” and “taking last odomtery”, the value stored in self.odom_record[-1] is same as the current odometry. Therefore you get a 0.0 for distance.
  2. When you have time.sleep() between “taking last odomtery” and “distance calculation”, you already have a new odometry value from the callback that has replaced the self.last_odom value. Therefore the distance calculated is not 0.0.
This is not the problem because of time.sleep() function. It is actually your programming fault, I would say. You are calculating the distance between the same points without you realizing it. Thus you have 0.0 as distance.
So, even if you remove the time.sleep() line completely, retrieving values by doing [-1] and [-2] would be a better way.
I hope I explained this to you clearly. Let me know if anything is unclear.
Thank you @girishkumar.kannan ! Your explanation is very clear.
My reasoning was that waiting one second at either of the 2 positions in the code wouldn’t make any difference, since waiting 1 second would be more than enough to have obtained a new measurement value from the /odom topic, since the messages received from the /odom topic are continuous and updated almost instantaneously. Isn’t that the case ?
Moreover, I did the code modifications but I’m still doing something wrong because the measurements are not being updated. You can find my modified code below:
import time
import rclpy
            Odometry,
            '/odom',
            self.odom_callback,
        self.last_x = 0.0
        self.last_y = 0.0
        self.second_last_x = 0.0
        self.second_last_y = 0.0
        self.last_x = 0.0
        self.last_y = 0.0
        # self.first_odom = self.last_odom
        # storing first measurement in an array of Point values
        self.odom_record.append(self.first_odom)
        iter = 0
        while True:
            iter += 1
            # taking the second to last odometry measurment stored in the odom_record array
            self.second_last_x = self.odom_record[-2].x
            self.second_last_y = self.odom_record[-2].y
            # DEBUGGING CODE
            self.get_logger().warn(f'odom_record= {self.odom_record}')
        [self.second_last_x, self.second_last_y])
                f"TOTAL DISTANCE= {self.total_distance}")
                                                  [self.first_odom.x, self.first_odom.y])
                break
            time.sleep(1.0)
        return result
    try:
        # spin the executor
        executor.spin()
    finally:
        executor.shutdown()
    rclpy.shutdown()
    main()
So, I tried to print the self.odom_record list that should be appended every second by a new measurement and I am getting the following:
user:~$ ros2 run wall_follower odometry_recording
[INFO] [1677625867.706852865] [odom_rec_action_server]: Executing goal...
[WARN] [1677625867.712652781] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0)]
[WARN] [1677625867.715435402] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625867.778698266] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.0
[WARN] [1677625868.780453251] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.295374784947808, y=-0.7419930810184633, z=0.0), geometry_msgs.msg.Point(x=0.295374784947808, y=-0.7419930810184633, z=0.0)]
[WARN] [1677625868.781877814] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625868.788748156] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.05914697233003422
[WARN] [1677625869.791362047] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.3539120537349092, y=-0.7556289095869357, z=0.0), geometry_msgs.msg.Point(x=0.3539120537349092, y=-0.7556289095869357, z=0.0), geometry_msgs.msg.Point(x=0.3539120537349092, y=-0.7556289095869357, z=0.0)]
[WARN] [1677625869.792428314] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625869.793457028] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.11925115360024838
[WARN] [1677625870.795455814] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.41190980676453354, y=-0.7692974374400218, z=0.0), geometry_msgs.msg.Point(x=0.41190980676453354, y=-0.7692974374400218, z=0.0), geometry_msgs.msg.Point(x=0.41190980676453354, y=-0.7692974374400218, z=0.0), geometry_msgs.msg.Point(x=0.41190980676453354, y=-0.7692974374400218, z=0.0)]
[WARN] [1677625870.796437178] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625870.797391611] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.1788377933862695
[WARN] [1677625871.801835515] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.4765469289854341, y=-0.7846640160931783, z=0.0), geometry_msgs.msg.Point(x=0.4765469289854341, y=-0.7846640160931783, z=0.0), geometry_msgs.msg.Point(x=0.4765469289854341, y=-0.7846640160931783, z=0.0), geometry_msgs.msg.Point(x=0.4765469289854341, y=-0.7846640160931783, z=0.0), geometry_msgs.msg.Point(x=0.4765469289854341, y=-0.7846640160931783, z=0.0)]
[WARN] [1677625871.802763770] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625871.803760503] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.2452762874659016
[WARN] [1677625872.810071824] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.5413347164416356, y=-0.800309477949111, z=0.0), geometry_msgs.msg.Point(x=0.5413347164416356, y=-0.800309477949111, z=0.0), geometry_msgs.msg.Point(x=0.5413347164416356, y=-0.800309477949111, z=0.0), geometry_msgs.msg.Point(x=0.5413347164416356, y=-0.800309477949111, z=0.0), geometry_msgs.msg.Point(x=0.5413347164416356, y=-0.800309477949111, z=0.0), geometry_msgs.msg.Point(x=0.5413347164416356, y=-0.800309477949111, z=0.0)]
[WARN] [1677625872.811211702] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625872.813842765] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.3119257040105355
[WARN] [1677625873.816616822] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.6089823698045758, y=-0.8152569572398175, z=0.0), geometry_msgs.msg.Point(x=0.6089823698045758, y=-0.8152569572398175, z=0.0), geometry_msgs.msg.Point(x=0.6089823698045758, y=-0.8152569572398175, z=0.0), geometry_msgs.msg.Point(x=0.6089823698045758, y=-0.8152569572398175, z=0.0), geometry_msgs.msg.Point(x=0.6089823698045758, y=-0.8152569572398175, z=0.0), geometry_msgs.msg.Point(x=0.6089823698045758, y=-0.8152569572398175, z=0.0), geometry_msgs.msg.Point(x=0.6089823698045758, y=-0.8152569572398175, z=0.0)]
[WARN] [1677625873.818231409] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625873.819106028] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.3811983384335323
[WARN] [1677625874.821885999] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.6740267431383826, y=-0.8243196978298237, z=0.0), geometry_msgs.msg.Point(x=0.6740267431383826, y=-0.8243196978298237, z=0.0), geometry_msgs.msg.Point(x=0.6740267431383826, y=-0.8243196978298237, z=0.0), geometry_msgs.msg.Point(x=0.6740267431383826, y=-0.8243196978298237, z=0.0), geometry_msgs.msg.Point(x=0.6740267431383826, y=-0.8243196978298237, z=0.0), geometry_msgs.msg.Point(x=0.6740267431383826, y=-0.8243196978298237, z=0.0), geometry_msgs.msg.Point(x=0.6740267431383826, y=-0.8243196978298237, z=0.0), geometry_msgs.msg.Point(x=0.6740267431383826, y=-0.8243196978298237, z=0.0)]
[WARN] [1677625874.822881428] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625874.823825731] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.4466358759249916
[WARN] [1677625875.877909982] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.7033999664976028, y=-0.824537118999082, z=0.0), geometry_msgs.msg.Point(x=0.7033999664976028, y=-0.824537118999082, z=0.0), geometry_msgs.msg.Point(x=0.7033999664976028, y=-0.824537118999082, z=0.0), geometry_msgs.msg.Point(x=0.7033999664976028, y=-0.824537118999082, z=0.0), geometry_msgs.msg.Point(x=0.7033999664976028, y=-0.824537118999082, z=0.0), geometry_msgs.msg.Point(x=0.7033999664976028, y=-0.824537118999082, z=0.0), geometry_msgs.msg.Point(x=0.7033999664976028, y=-0.824537118999082, z=0.0), geometry_msgs.msg.Point(x=0.7033999664976028, y=-0.824537118999082, z=0.0), geometry_msgs.msg.Point(x=0.7033999664976028, y=-0.824537118999082, z=0.0)]
[WARN] [1677625875.879260514] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625875.881100395] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.4754084505668387
[WARN] [1677625876.883414375] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.7280969908806795, y=-0.8181122314058265, z=0.0), geometry_msgs.msg.Point(x=0.7280969908806795, y=-0.8181122314058265, z=0.0), geometry_msgs.msg.Point(x=0.7280969908806795, y=-0.8181122314058265, z=0.0), geometry_msgs.msg.Point(x=0.7280969908806795, y=-0.8181122314058265, z=0.0), geometry_msgs.msg.Point(x=0.7280969908806795, y=-0.8181122314058265, z=0.0), geometry_msgs.msg.Point(x=0.7280969908806795, y=-0.8181122314058265, z=0.0), geometry_msgs.msg.Point(x=0.7280969908806795, y=-0.8181122314058265, z=0.0), geometry_msgs.msg.Point(x=0.7280969908806795, y=-0.8181122314058265, z=0.0), geometry_msgs.msg.Point(x=0.7280969908806795, y=-0.8181122314058265, z=0.0),geometry_msgs.msg.Point(x=0.7280969908806795, y=-0.8181122314058265, z=0.0)]
[WARN] [1677625876.884338697] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625876.885270081] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.4984219436755059
[WARN] [1677625877.887515371] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.7469404548224208, y=-0.8081801027288615, z=0.0), geometry_msgs.msg.Point(x=0.7469404548224208, y=-0.8081801027288615, z=0.0), geometry_msgs.msg.Point(x=0.7469404548224208, y=-0.8081801027288615, z=0.0), geometry_msgs.msg.Point(x=0.7469404548224208, y=-0.8081801027288615, z=0.0), geometry_msgs.msg.Point(x=0.7469404548224208, y=-0.8081801027288615, z=0.0), geometry_msgs.msg.Point(x=0.7469404548224208, y=-0.8081801027288615, z=0.0), geometry_msgs.msg.Point(x=0.7469404548224208, y=-0.8081801027288615, z=0.0), geometry_msgs.msg.Point(x=0.7469404548224208, y=-0.8081801027288615, z=0.0), geometry_msgs.msg.Point(x=0.7469404548224208, y=-0.8081801027288615, z=0.0),geometry_msgs.msg.Point(x=0.7469404548224208, y=-0.8081801027288615, z=0.0), geometry_msgs.msg.Point(x=0.7469404548224208, y=-0.8081801027288615, z=0.0)]
[WARN] [1677625877.888527101] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625877.889416462] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.5153359641461495
[WARN] [1677625878.891657939] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0), geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0), geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0), geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0), geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0), geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0), geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0), geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0), geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0),geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0), geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0), geometry_msgs.msg.Point(x=0.7679846788366173, y=-0.7895371797914175, z=0.0)]
[WARN] [1677625878.892566965] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625878.893514253] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.5336774179548724
[WARN] [1677625879.895727414] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0),geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0), geometry_msgs.msg.Point(x=0.8087493499607382, y=-0.7481537091643166, z=0.0)]
[WARN] [1677625879.896619086] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625879.897502899] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.5712637996086412
[WARN] [1677625880.899283634] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.23782996345199814, y=-0.728319827754327, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0),geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0), geometry_msgs.msg.Point(x=0.8351713802242293, y=-0.7182651464164492, z=0.0)]
[WARN] [1677625880.900221207] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677625880.901085428] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.5974260329181034
In addition, I should point out that I also found a weird bug (not really sure if it can be called a bug) in my code that almost made me give up on continuing the project :joy: It is in the following line of code when I store the first odometry measurement:
I tried to substitute the lines of code above with this line of code (which I thought would give the same result) :
In this case, the distance to the initial position stops getting updated and the odometry recording stops after 5 seconds. This is the action server output from the console in this case:
[INFO] [1677626235.320685099] [odom_rec_action_server]: Executing goal...
[WARN] [1677626235.321945398] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.5547032826879452, y=0.5557865812525365, z=0.0), geometry_msgs.msg.Point(x=0.5547032826879452, y=0.5557865812525365, z=0.0)]
[WARN] [1677626235.322835687] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677626235.324430318] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.0
[WARN] [1677626236.377964355] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.5014596900979499, y=0.572290276248157, z=0.0), geometry_msgs.msg.Point(x=0.5014596900979499, y=0.572290276248157, z=0.0), geometry_msgs.msg.Point(x=0.5014596900979499, y=0.572290276248157, z=0.0)]
[WARN] [1677626236.378885809] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677626236.379938184] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.0
[WARN] [1677626237.382746454] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.4379565079869966, y=0.5922506972722196, z=0.0), geometry_msgs.msg.Point(x=0.4379565079869966, y=0.5922506972722196, z=0.0), geometry_msgs.msg.Point(x=0.4379565079869966, y=0.5922506972722196, z=0.0), geometry_msgs.msg.Point(x=0.4379565079869966, y=0.5922506972722196, z=0.0)]
[WARN] [1677626237.383665330] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677626237.384541341] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.0
[WARN] [1677626238.385769460] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.3810057394472971, y=0.6102654289019764, z=0.0), geometry_msgs.msg.Point(x=0.3810057394472971, y=0.6102654289019764, z=0.0), geometry_msgs.msg.Point(x=0.3810057394472971, y=0.6102654289019764, z=0.0), geometry_msgs.msg.Point(x=0.3810057394472971, y=0.6102654289019764, z=0.0), geometry_msgs.msg.Point(x=0.3810057394472971, y=0.6102654289019764, z=0.0)]
[WARN] [1677626238.386649681] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677626238.392578035] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.0
[WARN] [1677626239.393791690] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.3238210334778244, y=0.6284666286161733, z=0.0), geometry_msgs.msg.Point(x=0.3238210334778244, y=0.6284666286161733, z=0.0), geometry_msgs.msg.Point(x=0.3238210334778244, y=0.6284666286161733, z=0.0), geometry_msgs.msg.Point(x=0.3238210334778244, y=0.6284666286161733, z=0.0), geometry_msgs.msg.Point(x=0.3238210334778244, y=0.6284666286161733, z=0.0), geometry_msgs.msg.Point(x=0.3238210334778244, y=0.6284666286161733, z=0.0)]
[WARN] [1677626239.396291726] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677626239.397833125] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.0
[WARN] [1677626240.399451811] [odom_rec_action_server]: odom_record= [geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0)]
[WARN] [1677626240.400380674] [odom_rec_action_server]: TOTAL DISTANCE= 0.0
[INFO] [1677626240.401295740] [odom_rec_action_server]: DISTANCE TO INITIAL POSITION= 0.0
[WARN] [1677626240.402297397] [odom_rec_action_server]: INITIAL POSITION REACHED!
[INFO] [1677626240.403461027] [odom_rec_action_server]: The list of odometry measurement is: [geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104,z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0), geometry_msgs.msg.Point(x=0.26392632897188073, y=0.6477457582545104, z=0.0)]
Thanks again for your help @girishkumar.kannan.
Hi @e.na.hatem ,
Yes, that is the case, you are correct. But it will be updated to the class variable that holds the current odometry values.
Your code has some silly issues that I cannot explain just by looking at your code.
The better way to fix your code is to debug your code by printing out each and every step, and then backtracking your result to fix the program.
It will take you some time, but I am sure when you discover the bug, you will realize it was a simple (stupid) mistake, which will help you understand the program logic better.
I guess, I will leave it to you for the debugging.
Let me know what was the issue after you debugged your program.
Thank you so much for your help @girishkumar.kannan !
No problem! You’re welcome @e.na.hatem !
– Girish
