Hi Girish,
Thanks for your response. I am working on Python.
This is the setup.py file
from setuptools import setup
import os
from glob import glob
package_name = 'actions_quiz'
setup(
name='my_action_client',
version='0.0.0',
packages=[package_name],
data_files=[
zip_safe=True,
maintainer='user',
tests_require=['pytest'],
entry_points={
'console_scripts': [
'action_quiz_server = actions_quiz.actions_quiz_server:main',
'action_quiz_client = actions_quiz.actions_quiz_client:main'
This is my main code:
import time
import numpy as np
import rclpy
from rclpy.action import ActionServer
from rclpy.node import Node
from rclpy.callback_groups import ReentrantCallbackGroup
from actions_quiz_msg.action import Distance
from std_msgs.msg import Float64
class ActionQuizServer(Node):
super().__init__('action_quiz_server')
self.group1 = ReentrantCallbackGroup()
self._action_server = ActionServer(self,
Distance,
'distance_as',
self.execute_callback,
callback_group=self.group1)
self.cmd_vel_publisher = self.create_publisher(Twist, 'cmd_vel', 10)
self.distance_publisher = self.create_publisher(Float64, '/total_distance', 10)
self.odom_subscriber_ = self.create_subscription(
Odometry,
'/odom',
self.odom_callback,
QoSProfile(depth=10, reliability=ReliabilityPolicy.RELIABLE),
self.start_pos_x = 0.0
self.start_pos_y = 0.0
self.start_pos_set = False
self.current_pos_x = 0.0
self.current_pos_y = 0.0
def odom_callback(self, msg):
if self.start_pos_set is False:
self.start_pos_x = msg.pose.pose.position.x
self.start_pos_y = msg.pose.pose.position.y
self.start_pos_set = True
else:
self.current_pos_x = msg.pose.pose.position.x
self.current_pos_y = msg.pose.pose.position.y
def get_distance_traveled(self):
dist_traveled = np.sqrt((self.current_pos_x - self.start_pos_x)**2 + (self.current_pos_y - self.start_pos_y)**2)
return dist_traveled
def execute_callback(self, goal_handle):
cmd_msg = Twist()
dist_msg = Float64()
self.get_logger().info('Executing goal...')
feedback_msg = Distance.Feedback()
for i in range(1, goal_handle.request.seconds):
cmd_msg.linear.x = 0.3
self.cmd_vel_publisher.publish(cmd_msg)
distance_traveled = self.get_distance_traveled()
feedback_msg.current_dist = distance_traveled
dist_msg.data = distance_traveled
goal_handle.publish_feedback(feedback_msg)
self.distance_publisher.publish(dist_msg)
self.get_logger().info('Current distance traveled: "%s" meters' %str(distance_traveled))
time.sleep(1)
self.get_logger().info('"%s" seconds have passed' %str(i + 1))
goal_handle.succeed()
cmd_msg.linear.x = 0.0
total_distance = self.get_distance_traveled()
result = Distance.Result()
result.status = True
result.total_dist = total_distance
self.get_logger().info('The action has finished')
self.get_logger().info('The robot has traveled: "%s" meters' %str(total_distance))
return result
def main(args=None):
rclpy.init(args=args)
action_server_node = ActionQuizServer()
executor = MultiThreadedExecutor(num_threads=2)
executor.add_node(action_server_node)
try:
executor.spin()
finally:
executor.shutdown()
action_server_node.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
Best regards,
Ronaldo
