Following on from running example 1.1 it is generating the following error in WebShell.
Also, trying to download manually is also not available, it’s in an infinite loop
Thanks for letting us know. We are looking into this and will get back to you.
It’s a privilege issue. Please add sudo to the command. I’ll update the notebook accordingly.
sudo evince frames.pdf
