Unit 3 Ex. 3.4 Typo Issue
I have just worked through the Ex 3.4 and the solution section has a few what seem to be typos rather than genuine issues: in the
def publish(self,x,y):
        msg = PoseWithCovarianceStamped()
        msg.header.frame_id = '/map'
        msg.pose.pose.position.x = x
        msg.pose.pose.position.y = y
        self.get_logger().info('Publishing  Initial Position  \n X= %f \n Y= %f '% (msg.point.x, msg.point.y))
        self.publisher_.publish(msg)
the logger info should be
        self.get_logger().info('Publishing  Initial Position  \n X= %f \n Y= %f '% (msg.pose.pose.position.x, msg.pose.pose.position.y))
the PoseWithCovarianceStamped has pose.pose.position.x format rather than point.x
Hello @roman.smid,
you are totally right, thanks for pointing that out :grinning:
The code has been corrected.
Cheers,
Roberto
