Hi all, I am working through the unit 3 in ROS 2 in Python course:
There is this bit in the notebook:
You should find a similar result in the terminal where you ran the command. Looking at what the shell shows you, you will see that the interfaces are divided into the following groups:
Messages: Can be found as
.msgfiles. They are simple text files that describe the fields of a ROS message. You can use them to generate source code for messages. -
Services: Can be found as
.srvfiles. They are composed of two parts: a request and a response. Both are message declarations. -
Actions: Can be found as
.actionfiles. They are composed of two parts: a request and a response. The request and response are message declarations.
What you are interested in at the moment are messages, so let’s go a little deeper into what they are.
However for the actions description - that should not be request and response but goal, result and feedback I think. This might be worth updating as it could confuse many newbies trying to learn ROS 2 using the ignite academy.
Let me know if I am wrong.
Thanks.
