It claims I am not subscribed to odom. I think it is a node name convential issue since the code runs fine when I run it. Any thoughts on where I went wrong because I have checked the launch file, setup and main code. I am included images of everything
i think you are missing a / before the topic name
Hi @lallyat
If your program works well try this:
- remove build, install and log folders
- resend your attempt
I tried both of those solutions and neither of them fixed my issue
Can you show the output of:
ros2 topic info /odom
while the quiz is launched locally (i.e. not submitted).
Hello @lallyat ,
From the image you shared, I can see the name of your node is topics_quiz, which is defined in the line:
super.__init__('topics_quiz')
I think you are confusing the node name with the executable name, which in your case it’s topics_quiz_node.
