I copied the code provided by the notebook into the test_process.py and start the process with
rosrun move_bb8_pkg test_process.py
but the simulation does not run and differently than in the pictures of the notebook the output of the system is not just telling me
[INFO] [1700753315.894701, 4170.406000]: Moving BB-8 forward!!
but also
[INFO] [1700753315.897402, 4170.408000]: shutdown time! Stop the robot
Code in my file:
#!/usr/bin/env python
class MoveBB8():
self.bb8_vel_publisher = rospy.Publisher('/cmd_vel', Twist, queue_size=1)
self.cmd = Twist()
self.ctrl_c = False
self.rate = rospy.Rate(1)
def publish_once_in_cmd_vel(self):
This is because publishing in topics sometimes fails the first time you publish.
In continuous publishing systems, this is no big deal, but in systems that publish only
once, it IS very important.
while not self.ctrl_c:
connections = self.bb8_vel_publisher.get_num_connections()
if connections > 0:
self.bb8_vel_publisher.publish(self.cmd)
break
else:
self.rate.sleep()
def shutdownhook(self):
# works better than the rospy.is_shutdown()
self.stop_bb8()
self.ctrl_c = True
def stop_bb8(self):
rospy.loginfo("shutdown time! Stop the robot")
self.cmd.linear.x = 0.0
self.cmd.angular.z = 0.0
self.publish_once_in_cmd_vel()
def move_bb8(self, linear_speed=0.2):
self.cmd.linear.x = -linear_speed
rospy.loginfo("Moving BB-8 forward!!")
self.rate.sleep()
self.stop_bb8()
if __name__ == '__main__':
rospy.init_node('process_test', anonymous=True)
movebb8_object = MoveBB8()
try:
movebb8_object.move_bb8()
pass
Code I copied from the textbook:
class MoveBB8():
self.cmd = Twist()
self.ctrl_c = False
if connections > 0:
break
else:
self.rate.sleep()
self.stop_bb8()
self.ctrl_c = True
def stop_bb8(self):
self.rate.sleep()
self.stop_bb8()
try:
pass
What is wrong?
