Unit 4 Exercise 4.3
Tried to run exercise 4.3 copied directly from the given solution. It seems to start OK but then I get the message:
File “/home/user/catkin_ws/src/exercise_33/publish_age.py”, line 4, in
from exercise_33.msg import Age #Import Age message from the exercise_33 package
ModuleNotFoundError: No module named ‘exercise_33’
[publish_age_node-1] process has died [pid 12762, exit code 1, cmd /home/user/catkin_ws/src/exercise_33/publish_age.py __name:=publish_age_node __log:=/home/user/.ros/log/578f292c-20eb-11ed-8d0b-0242ac1a0008/publish_age_node-1.log].
log file: /home/user/.ros/log/578f292c-20eb-11ed-8d0b-0242ac1a0008/publish_age_node-1*.log
done
The key problem is that it can’t find a node called exercise_33. I don’t understand this. There is a package called exercise_33, not a node. Line for in the publish_age.py script:
I don’t know what the file(?) named exercise_33.msg is. I am very confused. Please help.
thanks, Tom
Hi there @consi ,
I am almost going to finish ROS Basics in 5 Days with Python, so I believe that qualifies me to answer you.
The initial error line in the trace back says that there is no module named “exercise_33”. I believe you have copy-pasted the solution into your package that is not named as “exercise_33”.
Solution: Create a catkin package named “exercise_33” and then copy the solution on to it.
My advise: change the launch file node parameters to suit your program/package. Don’t copy from solution. If at all you want to take a look at the solution, understand the logic and re-implement yourself !
Copied from solution:
<launch>
    <node pkg="exercise_33" type="publish_age.py" name="publish_age_node" output="screen" />
</launch>
Breaking down the <node … /> line, we have:
catkin package name: “exercise_33” without quotes
python file name: “publish_age.py”
node name in the above python file : “publish_age_node” (this is the line in code rospy.init_node(“publish_age_node”))
output is usually “screen” to view the messages in stdout, which is terminal screen.
I have not executed or copy-pasted from the solutions but I am sure the solution will work fine.
Final advise: [Re]check your catkin package and/or code. Hope I helped!
I am having a similar problem. ROS doesn’t recognize the name of the package where the message is defined:
File “/home/user/catkin_ws/src/example_age/scripts/publish_age.py”, line 4, in
from example_age.msg import Age # Import Age message from the example_age package
ModuleNotFoundError: No module named ‘example_age’
The message is defined in the folder /msg inside the folder of the package example_age. ¿Could you help me with this issue?
Thanks!
Julio
Hi @juliogodoy ,
It is a very basic problem. Please go through your tutorial and redo your package.
You either did not make the package using catkin_create_pkg or missing out on Custom message CMake dependencies.
Follow the tutorial again to get it rectified.
This topic was automatically closed after 46 hours. New replies are no longer allowed.
