I have gone through and set up all the Exercises as guidance:
Here is my dynamixel_hardware_interface.cpp after all the exercises:
#include <algorithm>
#include <array>
#include <string>
#include <limits>
#include <vector>
#include "dynamixel_hardware_interface/dynamixel_hardware_interface.hpp"
#include "hardware_interface/types/hardware_interface_return_values.hpp"
#include "hardware_interface/types/hardware_interface_type_values.hpp"
#include "rclcpp/rclcpp.hpp"
namespace dynamixel_hardware
constexpr const char * kDynamixelHardware = "DynamixelHardware";
constexpr uint8_t kGoalPositionIndex = 0;
constexpr uint8_t kGoalVelocityIndex = 1;
constexpr uint8_t kPresentPositionVelocityCurrentIndex = 0;
constexpr const char * kGoalPositionItem = "Goal_Position";
constexpr const char * kGoalVelocityItem = "Goal_Velocity";
constexpr const char * kMovingSpeedItem = "Moving_Speed";
constexpr const char * kPresentPositionItem = "Present_Position";
constexpr const char * kPresentVelocityItem = "Present_Velocity";
constexpr const char * kPresentSpeedItem = "Present_Speed";
constexpr const char * kPresentCurrentItem = "Present_Current";
constexpr const char * kPresentLoadItem = "Present_Load";
CallbackReturn DynamixelHardware::on_init(const hardware_interface::HardwareInfo & info)
RCLCPP_DEBUG(rclcpp::get_logger(kDynamixelHardware), "configure");
if (hardware_interface::SystemInterface::on_init(info) != CallbackReturn::SUCCESS)
return CallbackReturn::ERROR;
joints_.resize(info_.joints.size(), Joint());
joint_ids_.resize(info_.joints.size(), 0);
for (uint i = 0; i < info_.joints.size(); i++) {
joint_ids_[i] = std::stoi(info_.joints[i].parameters.at("id"));
joints_[i].state.position = std::numeric_limits<double>::quiet_NaN();
joints_[i].state.velocity = std::numeric_limits<double>::quiet_NaN();
joints_[i].state.effort = std::numeric_limits<double>::quiet_NaN();
joints_[i].command.position = std::numeric_limits<double>::quiet_NaN();
joints_[i].command.velocity = std::numeric_limits<double>::quiet_NaN();
joints_[i].command.effort = std::numeric_limits<double>::quiet_NaN();
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "joint_id %d: %d", i, joint_ids_[i]);
if (
info_.hardware_parameters.find("use_dummy") != info_.hardware_parameters.end() &&
info_.hardware_parameters.at("use_dummy") == "true") {
use_dummy_ = true;
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "dummy mode");
return CallbackReturn::SUCCESS;
auto usb_port = info_.hardware_parameters.at("usb_port");
auto baud_rate = std::stoi(info_.hardware_parameters.at("baud_rate"));
const char * log = nullptr;
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "usb_port: %s", usb_port.c_str());
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "baud_rate: %d", baud_rate);
if (!dynamixel_workbench_.init(usb_port.c_str(), baud_rate, &log)) {
RCLCPP_FATAL(rclcpp::get_logger(kDynamixelHardware), "%s", log);
for (uint i = 0; i < info_.joints.size(); ++i) {
uint16_t model_number = 0;
if (!dynamixel_workbench_.ping(joint_ids_[i], &model_number, &log)) {
enable_torque(false);
set_control_mode(ControlMode::Position, true);
enable_torque(true);
const ControlItem * goal_position =
dynamixel_workbench_.getItemInfo(joint_ids_[0], kGoalPositionItem);
if (goal_position == nullptr) {
const ControlItem * goal_velocity =
dynamixel_workbench_.getItemInfo(joint_ids_[0], kGoalVelocityItem);
if (goal_velocity == nullptr) {
goal_velocity = dynamixel_workbench_.getItemInfo(joint_ids_[0], kMovingSpeedItem);
const ControlItem * present_position =
dynamixel_workbench_.getItemInfo(joint_ids_[0], kPresentPositionItem);
if (present_position == nullptr) {
const ControlItem * present_velocity =
dynamixel_workbench_.getItemInfo(joint_ids_[0], kPresentVelocityItem);
if (present_velocity == nullptr) {
present_velocity = dynamixel_workbench_.getItemInfo(joint_ids_[0], kPresentSpeedItem);
const ControlItem * present_current =
dynamixel_workbench_.getItemInfo(joint_ids_[0], kPresentCurrentItem);
if (present_current == nullptr) {
present_current = dynamixel_workbench_.getItemInfo(joint_ids_[0], kPresentLoadItem);
control_items_[kGoalPositionItem] = goal_position;
control_items_[kGoalVelocityItem] = goal_velocity;
control_items_[kPresentPositionItem] = present_position;
control_items_[kPresentVelocityItem] = present_velocity;
control_items_[kPresentCurrentItem] = present_current;
if (!dynamixel_workbench_.addSyncWriteHandler(
control_items_[kGoalPositionItem]->address, control_items_[kGoalPositionItem]->data_length,
&log)) {
control_items_[kGoalVelocityItem]->address, control_items_[kGoalVelocityItem]->data_length,
&log)) {
uint16_t start_address = std::min(
control_items_[kPresentPositionItem]->address, control_items_[kPresentCurrentItem]->address);
uint16_t read_length = control_items_[kPresentPositionItem]->data_length +
control_items_[kPresentVelocityItem]->data_length +
control_items_[kPresentCurrentItem]->data_length + 2;
if (!dynamixel_workbench_.addSyncReadHandler(start_address, read_length, &log)) {
std::vector<hardware_interface::StateInterface> DynamixelHardware::export_state_interfaces()
RCLCPP_DEBUG(rclcpp::get_logger(kDynamixelHardware), "export_state_interfaces");
std::vector<hardware_interface::StateInterface> state_interfaces;
state_interfaces.emplace_back(hardware_interface::StateInterface(
info_.joints[i].name, hardware_interface::HW_IF_POSITION, &joints_[i].state.position));
info_.joints[i].name, hardware_interface::HW_IF_VELOCITY, &joints_[i].state.velocity));
info_.joints[i].name, hardware_interface::HW_IF_EFFORT, &joints_[i].state.effort));
return state_interfaces;
std::vector<hardware_interface::CommandInterface> DynamixelHardware::export_command_interfaces()
RCLCPP_DEBUG(rclcpp::get_logger(kDynamixelHardware), "export_command_interfaces");
std::vector<hardware_interface::CommandInterface> command_interfaces;
command_interfaces.emplace_back(hardware_interface::CommandInterface(
info_.joints[i].name, hardware_interface::HW_IF_POSITION, &joints_[i].command.position));
info_.joints[i].name, hardware_interface::HW_IF_VELOCITY, &joints_[i].command.velocity));
return command_interfaces;
CallbackReturn DynamixelHardware::on_activate(const rclcpp_lifecycle::State & previous_state)
RCLCPP_DEBUG(rclcpp::get_logger(kDynamixelHardware), "start");
for (uint i = 0; i < joints_.size(); i++) {
if (use_dummy_ && std::isnan(joints_[i].state.position)) {
joints_[i].state.position = 0.0;
joints_[i].state.velocity = 0.0;
joints_[i].state.effort = 0.0;
read();
reset_command();
write();
CallbackReturn DynamixelHardware::on_deactivate(const rclcpp_lifecycle::State & previous_state)
RCLCPP_DEBUG(rclcpp::get_logger(kDynamixelHardware), "stop");
return_type DynamixelHardware::read()
if (use_dummy_) {
return return_type::OK;
std::vector<uint8_t> ids(info_.joints.size(), 0);
std::vector<int32_t> positions(info_.joints.size(), 0);
std::vector<int32_t> velocities(info_.joints.size(), 0);
std::vector<int32_t> currents(info_.joints.size(), 0);
std::copy(joint_ids_.begin(), joint_ids_.end(), ids.begin());
if (!dynamixel_workbench_.syncRead(
kPresentPositionVelocityCurrentIndex, ids.data(), ids.size(), &log)) {
RCLCPP_ERROR(rclcpp::get_logger(kDynamixelHardware), "%s", log);
if (!dynamixel_workbench_.getSyncReadData(
control_items_[kPresentCurrentItem]->address,
control_items_[kPresentCurrentItem]->data_length, currents.data(), &log)) {
control_items_[kPresentVelocityItem]->address,
control_items_[kPresentVelocityItem]->data_length, velocities.data(), &log)) {
control_items_[kPresentPositionItem]->data_length, positions.data(), &log)) {
for (uint i = 0; i < ids.size(); i++) {
joints_[i].state.position = dynamixel_workbench_.convertValue2Radian(ids[i], positions[i]);
joints_[i].state.velocity = dynamixel_workbench_.convertValue2Velocity(ids[i], velocities[i]);
joints_[i].state.effort = dynamixel_workbench_.convertValue2Current(currents[i]);
return_type DynamixelHardware::write()
if (use_dummy_) {
for (auto & joint : joints_) {
joint.state.position = joint.command.position;
std::vector<int32_t> commands(info_.joints.size(), 0);
if (std::any_of(
joints_.cbegin(), joints_.cend(), [](auto j) { return j.command.velocity != 0.0; })) {
// Velocity control
set_control_mode(ControlMode::Velocity);
commands[i] = dynamixel_workbench_.convertVelocity2Value(
ids[i], static_cast<float>(joints_[i].command.velocity));
if (!dynamixel_workbench_.syncWrite(
kGoalVelocityIndex, ids.data(), ids.size(), commands.data(), 1, &log)) {
} else if (std::any_of(
joints_.cbegin(), joints_.cend(), [](auto j) { return j.command.effort != 0.0; })) {
// Effort control
RCLCPP_ERROR(rclcpp::get_logger(kDynamixelHardware), "Effort control is not implemented");
return return_type::ERROR;
// Position control
set_control_mode(ControlMode::Position);
commands[i] = dynamixel_workbench_.convertRadian2Value(
ids[i], static_cast<float>(joints_[i].command.position));
kGoalPositionIndex, ids.data(), ids.size(), commands.data(), 1, &log)) {
return_type DynamixelHardware::enable_torque(const bool enabled)
if (enabled && !torque_enabled_) {
if (!dynamixel_workbench_.torqueOn(joint_ids_[i], &log)) {
reset_command();
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "Torque enabled");
} else if (!enabled && torque_enabled_) {
if (!dynamixel_workbench_.torqueOff(joint_ids_[i], &log)) {
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "Torque disabled");
torque_enabled_ = enabled;
return_type DynamixelHardware::set_control_mode(const ControlMode & mode, const bool force_set)
if (mode == ControlMode::Velocity && (force_set || control_mode_ != ControlMode::Velocity)) {
bool torque_enabled = torque_enabled_;
if (torque_enabled) {
for (uint i = 0; i < joint_ids_.size(); ++i) {
if (!dynamixel_workbench_.setVelocityControlMode(joint_ids_[i], &log)) {
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "Velocity control");
control_mode_ = ControlMode::Velocity;
} else if (
mode == ControlMode::Position && (force_set || control_mode_ != ControlMode::Position)) {
if (!dynamixel_workbench_.setPositionControlMode(joint_ids_[i], &log)) {
RCLCPP_INFO(rclcpp::get_logger(kDynamixelHardware), "Position control");
control_mode_ = ControlMode::Position;
} else if (control_mode_ != ControlMode::Velocity && control_mode_ != ControlMode::Position) {
RCLCPP_FATAL(
rclcpp::get_logger(kDynamixelHardware), "Only position/velocity control are implemented");
return_type DynamixelHardware::reset_command()
joints_[i].command.position = joints_[i].state.position;
joints_[i].command.velocity = 0.0;
joints_[i].command.effort = 0.0;
} // namespace dynamixel_hardware
#include "pluginlib/class_list_macros.hpp"
PLUGINLIB_EXPORT_CLASS(dynamixel_hardware::DynamixelHardware, hardware_interface::SystemInterface)
And below is the error from the terminal which make the package compiled unsuccessfully:
user:~/ros2_ws$ colcon build --symlink-install
[0.339s] WARNING:colcon.colcon_core.package_identification:Failed to parse ROS package manifest in 'src/dynamixel_hardware_interface': Error(s) in package 'src/dynamixel_hardware_interface/package.xml':
Invalid email "to-do" for person "user"
[0.469s] WARNING:colcon.colcon_core.verb:Some selected packages are already built in one or more underlay workspaces:
'diffbot_description' is in: /home/user/ros2_ws/install/diffbot_description
'diffbot_sim' is in: /home/user/ros2_ws/install/diffbot_sim
'dynamixel_sdk' is in: /home/user/ros2_ws/install/dynamixel_sdk
'dynamixel_sdk_custom_interfaces' is in: /home/user/ros2_ws/install/dynamixel_sdk_custom_interfaces
'joint_trajectory_publisher' is in: /home/user/ros2_ws/install/joint_trajectory_publisher
'my_robot_bringup' is in: /home/user/ros2_ws/install/my_robot_bringup
'my_robot_hardware_interface' is in: /home/user/ros2_ws/install/my_robot_hardware_interface
'rrbot_unit2' is in: /home/user/ros2_ws/install/rrbot_unit2
'rrbot_unit3' is in: /home/user/ros2_ws/install/rrbot_unit3
'rrbot_unit4' is in: /home/user/ros2_ws/install/rrbot_unit4
'rrbot_unit5' is in: /home/user/ros2_ws/install/rrbot_unit5
'solo_description' is in: /home/user/ros2_ws/install/solo_description
'spawn_robot' is in: /home/user/ros2_ws/install/spawn_robot
'spawn_solo' is in: /home/user/ros2_ws/install/spawn_solo
'dynamixel_sdk_examples' is in: /home/user/ros2_ws/install/dynamixel_sdk_examples
'dynamixel_workbench_toolbox' is in: /home/user/ros2_ws/install/dynamixel_workbench_toolbox
'dynamixel_hardware_interface' is in: /home/user/ros2_ws/install/dynamixel_hardware_interface
'dynamixel_workbench' is in: /home/user/ros2_ws/install/dynamixel_workbench
If a package in a merged underlay workspace is overridden and it installs headers, then all packages in the overlay must sort their include directories by workspace order. Failure to do so may result in build failures or undefined behavior at run time.
If the overridden package is used by another package in any underlay, then the overriding package in the overlay must be API and ABI compatible or undefined behavior at run time may occur.
If you understand the risks and want to override a package anyways, add the following to the command line:
--allow-overriding diffbot_description diffbot_sim dynamixel_hardware_interface dynamixel_sdk dynamixel_sdk_custom_interfaces dynamixel_sdk_examples dynamixel_workbench dynamixel_workbench_toolbox joint_trajectory_publisher my_robot_bringup my_robot_hardware_interface rrbot_unit2 rrbot_unit3 rrbot_unit4 rrbot_unit5 solo_description spawn_robot spawn_solo
This may be promoted to an error in a future release of colcon-core.
Starting >>> dynamixel_sdk
Starting >>> dynamixel_sdk_custom_interfaces
Starting >>> diffbot_description
Starting >>> diffbot_sim
Starting >>> joint_trajectory_publisher
Starting >>> my_robot_bringup
Starting >>> my_robot_hardware_interface
Starting >>> rrbot_unit2
Finished <<< diffbot_description [1.70s]
Starting >>> rrbot_unit3
Finished <<< my_robot_bringup [1.82s]
Finished <<< diffbot_sim [1.87s]
Starting >>> rrbot_unit4
Starting >>> rrbot_unit5
Finished <<< rrbot_unit2 [1.92s]
Starting >>> solo_description
Finished <<< dynamixel_sdk [2.30s]
Finished <<< my_robot_hardware_interface [2.20s]
Starting >>> dynamixel_workbench_toolbox
Starting >>> spawn_robot
Finished <<< rrbot_unit3 [1.50s]
Starting >>> spawn_solo
Finished <<< rrbot_unit5 [1.45s]
Finished <<< spawn_robot [1.13s]
Finished <<< solo_description [1.42s]
Finished <<< rrbot_unit4 [1.61s]
Finished <<< dynamixel_workbench_toolbox [1.52s]
Starting >>> dynamixel_hardware_interface
Finished <<< spawn_solo [0.89s]
Finished <<< dynamixel_sdk_custom_interfaces [4.33s]
Starting >>> dynamixel_sdk_examples
Finished <<< dynamixel_workbench [0.66s]
Finished <<< joint_trajectory_publisher [4.78s]
Finished <<< dynamixel_sdk_examples [0.71s]
--- stderr: dynamixel_hardware_interface
Error parsing '/home/user/ros2_ws/src/dynamixel_hardware_interface/package.xml':
File "/opt/ros/galactic/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 151, in <module>
main()
File "/opt/ros/galactic/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 54, in main
raise e
File "/opt/ros/galactic/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 50, in main
package = parse_package_string(
File "/usr/lib/python3/dist-packages/catkin_pkg/package.py", line 774, in parse_package_string
pkg.validate(warnings=warnings)
File "/usr/lib/python3/dist-packages/catkin_pkg/package.py", line 317, in validate
raise InvalidPackage('\n'.join(errors), self.filename)
catkin_pkg.package.InvalidPackage: Error(s) in package '/home/user/ros2_ws/src/dynamixel_hardware_interface/package.xml':
CMake Error at /opt/ros/galactic/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:94 (message):
execute_process(/usr/bin/python3
/home/user/ros2_ws/build/dynamixel_hardware_interface/ament_cmake_core/package.cmake)
returned error code 1
/opt/ros/galactic/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:49 (_ament_package_xml)
/opt/ros/galactic/share/ament_lint_auto/cmake/ament_lint_auto_find_test_dependencies.cmake:31 (ament_package_xml)
CMakeLists.txt:71 (ament_lint_auto_find_test_dependencies)
make: *** [Makefile:222: cmake_check_build_system] Error 1
Failed <<< dynamixel_hardware_interface [2.53s, exited with code 2]
Summary: 17 packages finished [6.67s]
1 package failed: dynamixel_hardware_interface
1 package had stderr output: dynamixel_hardware_interface
user:~/ros2_ws$
