Hi Péter,
you indicated two points:
1st point: voxel_layer mentioned in documentation but not added to the actual config file
In the documentation we mention that there exist several plugins to be applied to the global_costmap:
- The
static_layer
- The
inflation_layer
- The
obstacle_layer
- The
voxel_layer (this one is like the previous one but for 3D sensors that provide a pointcloud of distances measurements)
Hence, you can add to you configuration file whichever of those that you need for your specific application. In our example, we use only the first 3 plugins. We do not use the voxel_layer because we do not have a pointcloud device on the robot, only a lidar
But you can use all of them at once if you have so many sensors. Actually, you can even have several
obstacle_layer and several voxel_layer at the same time if you have so many sensors in your robot.
Remember, though, that the words voxel_layer or obstacle_layer or inflation_layer are just labels we decided to differentiate the config of each plugin. You can put any label to the plugin list, as long as the same name corresponds to the plugin configuration below.
Actually, if you have several lidars you will need to add each one with a different layer and hence, different configuration. One label for each device, one configuration for each device.
Example for a robot with 2 lidars and one pointcloud:
plugins: ["static_layer", "obstacle_layer1", "obstacle_layer2", "point_cloud_layer", "inflation_layer"]
obstacle_layer1:
plugin: "nav2_costmap_2d::ObstacleLayer"
enabled: True
observation_sources: scan
scan:
topic: /scan_1
max_obstacle_height: 2.0
clearing: True
marking: True
data_type: "LaserScan"
raytrace_max_range: 3.0
raytrace_min_range: 0.0
obstacle_max_range: 2.5
obstacle_min_range: 0.0
obstacle_layer2:
enabled: True
scan:
topic: /scan_2
clearing: True
marking: True
point_cloud_layer:
plugin: "nav2_costmap_2d::VoxelLayer"
enabled: True
footprint_clearing_enabled: true
publish_voxel_map: True
origin_z: 0.0
z_resolution: 0.05
z_voxels: 16
unknown_threshold: 15
mark_threshold: 0
observation_sources: pointcloud
combination_method: 1
pointcloud: # no frame set, uses frame from message
topic: /intel_realsense_r200_depth/points
min_obstacle_height: 0.0
clearing: True
marking: True
data_type: "PointCloud2"
2nd point: in local_costmap the static_layer is added to the config but not used
You are right!
The config for the local_costmap is as follows:
plugins: ["voxel_layer", "inflation_layer"]
inflation_layer:
plugin: "nav2_costmap_2d::InflationLayer"
cost_scaling_factor: 3.0
inflation_radius: 0.35
voxel_layer:
enabled: True
origin_z: 0.0
z_resolution: 0.05
z_voxels: 16
mark_threshold: 0
scan:
topic: /scan
clearing: True
marking: True
static_layer:
map_subscribe_transient_local: True
At the end of the file, we are indicating the config parameters for the static_layer but the plugins list doesn’t include it. That means that the static_layer is not actually used (only the parts included in the plugins list are actually used for computing the costmap).
So we can get rid of the config part of static_layer for the local_costmap
