Unit 6: Exercise 6.3 - No module named “my_custom_srv_msg_pkg”
Hi, I got a problem.
Normally, I create:
  1. unit_5_services package
  2. MyCustomServiceMessage
  3. Service Server
  4. Service Client
  5. Then start service server → call service from client.
    Everything is ok.
But when I create another package with MyCustomServiceMessage inside, I change import command from:
from unit_5_services.srv import MyCustomServiceMessage, MyCustomServiceMessageResponse
to:
from my_custom_srv_msg_pkg.srv import MyCustomServiceMessage, MyCustomServiceMessageResponse
I got error: no modules named “my_custom_srv_msg_pkg”
Please check and help me.
project(unit_5_services)
  rospy
  std_msgs
  message_generation
# catkin_python_setup()
##   your messages/services/actions (e.g. std_msgs, actionlib_msgs, ...).
## * In the file package.xml:
##   * add a build_depend tag for "message_generation"
##   * add a build_depend and a exec_depend tag for each package in MSG_DEP_SET
##   * If MSG_DEP_SET isn't empty the following dependency has been pulled in
##     but can be declared for certainty nonetheless:
##     * add a exec_depend tag for "message_runtime"
##   * add "message_generation" and every package in MSG_DEP_SET to
##     find_package(catkin REQUIRED COMPONENTS ...)
##   * add "message_runtime" and every package in MSG_DEP_SET to
##     catkin_package(CATKIN_DEPENDS ...)
##   * uncomment the add_*_files sections below as needed
##     and list every .msg/.srv/.action file to be processed
##   * uncomment the generate_messages entry below
##   * add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES ...)
# add_message_files(
#   FILES
#   Message1.msg
#   Message2.msg
add_service_files(
  FILES
  MyCustomServiceMessage.srv
#   Service2.srv
# add_action_files(
#   FILES
#   Action1.action
#   Action2.action
generate_messages(
  DEPENDENCIES
  std_msgs
##   * add a build_depend and a exec_depend tag for "dynamic_reconfigure"
##   * add "dynamic_reconfigure" to
##   * uncomment the "generate_dynamic_reconfigure_options" section below
##     and list every .cfg file to be processed
#   cfg/DynReconf1.cfg
#   cfg/DynReconf2.cfg
catkin_package(
#  INCLUDE_DIRS include
#  LIBRARIES unit_5_services
 CATKIN_DEPENDS rospy std_msgs
#  DEPENDS system_lib
## Build ##
include_directories(
# include
  ${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
#   src/${PROJECT_NAME}/unit_5_services.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/unit_5_services_node.cpp)
#   ${catkin_LIBRARIES}
## Install ##
#   scripts/my_python_script
#   DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
#   ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
#   RUNTIME DESTINATION ${CATKIN_GLOBAL_BIN_DESTINATION}
#   DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
#   FILES_MATCHING PATTERN "*.h"
#   PATTERN ".svn" EXCLUDE
# install(FILES
#   # myfile1
#   # myfile2
#   DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_unit_5_services.cpp)
#   target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME})
# endif()
# catkin_add_nosetests(test)
<?xml version="1.0"?>
<package format="2">
  <name>unit_5_services</name>
  <version>0.0.0</version>
  <description>The unit_5_services package</description>
  <!-- Example:  -->
  <!--   BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
  <license>TODO</license>
  <!-- Example: -->
  <!-- <url type="website">http://wiki.ros.org/unit_5_services</url> -->
  <!-- Example: -->
  <!-- Examples: -->
  <!--   <depend>roscpp</depend> -->
  <!--   Note that this is equivalent to the following: -->
  <!--   <build_depend>roscpp</build_depend> -->
  <!--   <exec_depend>roscpp</exec_depend> -->
  <!--   <build_depend>message_generation</build_depend> -->
  <!--   <build_export_depend>message_generation</build_export_depend> -->
  <!--   <buildtool_depend>catkin</buildtool_depend> -->
  <!--   <exec_depend>message_runtime</exec_depend> -->
  <!--   <test_depend>gtest</test_depend> -->
  <!--   <doc_depend>doxygen</doc_depend> -->
  <build_depend>std_srvs</build_depend>
  <build_depend>geometry_msgs</build_depend>
  <build_depend>my_custom_srv_msg_pkg</build_depend>
  <build_export_depend>std_srvs</build_export_depend>
  <build_export_depend>geometry_msgs</build_export_depend>
  <build_export_depend>my_custom_srv_msg_pkg</build_export_depend>
  <exec_depend>std_srvs</exec_depend>
  <exec_depend>geometry_msgs</exec_depend>
  <exec_depend>my_custom_srv_msg_pkg</exec_depend>
  <export>
  </export>
</package>
One more thing, I used:
  1. catkin_make (with --only… and without --only…)
  2. source devel/setup.bash
Then I run rosrun/roslaunch in the same terminal, but the error still happens
Hi @NguyenDuyDuc ,
If I understood your problem correctly,
You would like to use MyCustomServiceMessage from my_custom_srv_msg_pkg package in your program that is inside the unit_5_services package?
If that is the problem then what you should do is:
  1. Add my_custom_srv_msg_pkg under find_package in CMakeLists.txt file of unit_5_services package.
  2. Add my_custom_srv_msg_pkg under catkin_package with CATKIN_DEPENDS in CMakeLists.txt file of unit_5_services package.
Your package.xml file of unit_5_services package looks fine. No changes needed.
That should solve your problem. Let me know if this does not solve your problem.
Thank you. I got it.
