Hello.
Somehow I do not really get why there is so much code provided in this exercise.
Should I put this code in the robot_control_class.py (update it) and then import the updated robot_control_class.py to my code to get out of the maze?
Hi @LenaP, welcome to the community!
The file robot_control_class.py is a Python Class that you can use in a different file in order to implement the methods you need to get out of the maze, yes.
What do you mean by “(update it)”, could you send a screenshot of what you mean?
I am talking about the code in the exercise. Should I replace the code in the robot_control_class.py in the workspace with the code provided in the exercise?
Hi @LenaP,
in the second unit of the course, you are asked to create a file named robot_control_class.py inside your ~/catkin_ws/src folder.
The class contains many methods, but there is not a method called rotate.
In the Unit 6 - Project, we are told that we are going to use a new method, called rotate:
Finally, and for this project, you are going to be able to use a new method.
rotate (degrees): This method will allow your robot to rotate for the specified number of degrees.
degrees: The number of degrees you want your robot to rotate.
Since in the robot_control_class.py used in the previous Units do not contain the rotate method, the instructions then present the updated code with the rotate method:
Below you can find the updated code for the
robot_control_class.pyclass, which contains the newrotate()method.
You just have to replace the code in robot_control_class.py with the new code provided in Unit 6, so that you can use the rotate method.
Please let us know if you still need help on this.
