Unit 6: Services in ROS: Servers & Messages: Compile error
Course: ROS Basics in 5 days (C++)
Unit: Unit 6 Services in ROS: Servers & Messages
Section: Exercise 6.3
I got the following error when I’m trying to compile the package(catkin_make). the error I’m getting is for Unit 5 which compile perfectly without any error in the previous section.
In order to avoid this error I just compile one package with this command: $ catkin_make --only-pkg-with-deps service_server_pkg
Is there any other way to compile the entire workspace without getting this error ?
Thanks
Please try the following to only compile the package for the exercise.
catkin_make --only-pkg-with-deps <target_package>
The Unit 5 package is probably failing because some of its dependencies are not available in the current unit.
Thank you for your feedback
