When I try to grade the services quiz, it relatively quickly ends with zero points, and no line items:
I’ve double checked naming of everything and it looks fine.
I also got this same problem, does anyone know how to fix it?
Hi, welcome to the community!
Please, when you are grading the quiz, make sure that all processes are killed in your terminals. This might be causing the issue.
I am pretty sure I killed all processes in my terminals. I also restart the whole system and try it the second time, but I still got zero mark.
The other thing to check is to go through the names of the files. They need to be exactly the same as the instructions indicate in order for the grader to work. If those things don’t work let me know and we’ll look into it for you
As shown in the following picture, I think the names of my files are the same as those in the specification.
Ok, thanks for checking. Just last thing, is the name of your service /move_bb8_in_square_custom?
We are looking into this issue and will get back to you as soon as posible.
Yes. That’s my service name.
we just did a new deployment.
Could you try to submit the quiz again?
I look forward to hearing from you.
I just resubmitted my work, it seems everything works fine. Just to make sure, the full mark of every quiz is 10, right?
Yes, 10 is the full mark
