Unit 6 - Understanding ROS Services - Server Terminal Issue
I am getting this error. If I type the same command in terminal 1, the command is executed without any error. Since I have to launch two launch files simultaneously, I need both terminals to work. What exactly is the problem?
Hello @rutweek.joshi ,
Just did some tests with your files and it is working properly. Can you confirm this is already solved?
Thank You. I just checked if it was working and it did.
