This is the solution I proposed for the unit final quiz.
#include "ros/duration.h"
#include "ros/init.h"
#include "ros/publisher.h"
#include <actionlib/server/simple_action_server.h>
#include <actionlib_tutorials/FibonacciAction.h>
#include <actions_quiz/CustomActionMsgAction.h>
#include <actions_quiz/CustomActionMsgFeedback.h>
#include <actions_quiz/CustomActionMsgGoal.h>
#include <ros/ros.h>
#include <std_msgs/Empty.h>
class Handler {
protected:
ros::NodeHandle nh_;
actionlib::SimpleActionServer<actions_quiz::CustomActionMsgAction> as_;
ros::Publisher take_off_pub =
nh_.advertise<std_msgs::Empty>("/drone/takeoff", 1000);
ros::Publisher land_pub = nh_.advertise<std_msgs::Empty>("/drone/land", 1000);
std_msgs::Empty empty;
public:
Handler(std::string name)
as_(nh_, name, boost::bind(&Handler::execute, this, _1), false) {
as_.start();
void execute(const actions_quiz::CustomActionMsgGoalConstPtr &goal) {
ros::Rate loop_rate(2);
ROS_INFO_STREAM(" Received " << goal->goal);
if (goal->goal == "TAKEOFF") {
take_off_pub.publish(empty);
} else if (goal->goal == "LAND") {
land_pub.publish(empty);
actions_quiz::CustomActionMsgFeedback feedback;
feedback.feedback = goal->goal;
ros::spinOnce();
for (int i = 0; i < 4; ++i) {
ros::spinOnce();
loop_rate.sleep();
as_.publishFeedback(feedback);
ROS_INFO_STREAM("Done");
as_.setSucceeded();
ros::init(argc, argv, "action_custom_msg_as_node");
Handler handler("action_custom_msg_as");
ros::spin();
return 0;
This is what i get from autocorrection:
✔ [18:52:16] [info] Checking that the TAKEOFF call works... (mark: 6.0)
✖ [18:52:52] [assess] Drone did not take off. C'mon, even grandpas can do this!
- Is your code taking the drone off correctly?
- Is your code landing the drone after taking it off? It should NOT. You should use the LAND call for that. (mark: 6.0)
✔ [18:52:55] [info] Checking that the LAND call works... (mark: 6.0)
✖ [18:53:35] [assess] Drone was not landed. You intend to keep it hanging in the air?
- Is your code landing the drone correctly?
- Is your code taking the drone off after landing it? It should NOT. You should use the TAKEOFF call for that. (mark: 6.0)
The drone lands and take off correctly by calling:
rostopic pub /action_custom_msg_as/goal actions_quiz/CustomActionMsgActionGoal "header:
seq: 0
stamp:
secs: 0
nsecs: 0
frame_id: ''
goal_id:
stamp:
secs: 0
nsecs: 0
goal:
goal: 'LAND'"
The autocorrection claims it does not. What am I doing wrong?
Thanks,
