Unit1 has problem
source /home/simulations/ros2_sims_ws/install/setup.bash
ros2 run commanding_the_robot U1_agent
File “/home/simulations/ros2_sims_ws/install/commanding_the_robot/lib/commanding_the_robot/U1_agent”, line 33, in
sys.exit(load_entry_point(‘commanding-the-robot==0.0.0’, ‘console_scripts’, ‘U1_agent’)())
File “/home/simulations/ros2_sims_ws/install/commanding_the_robot/lib/commanding_the_robot/U1_agent”, line 25, in importlib_load_entry_point
return next(matches).load()
File “/usr/lib/python3.10/importlib/metadata/init.py”, line 171, in load
module = import_module(match.group(‘module’))
File “/usr/lib/python3.10/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1050, in _gcd_import
File “”, line 1027, in _find_and_load
File “”, line 1006, in _find_and_load_unlocked
File “”, line 688, in _load_unlocked
File “”, line 883, in exec_module
File “”, line 241, in _call_with_frames_removed
File “/home/simulations/ros2_sims_ws/install/commanding_the_robot/lib/python3.10/site-packages/commanding_the_robot/U1_agent.py”, line 2, in
from llama_cpp import Llama
ModuleNotFoundError: No module named ‘llama_cpp’
[ros2run]: Process exited with failure 1
I apologize for this glitch. Let’s look into that and get back to you ASAP.
Sorry for the late fix. We have just deployed and tested the new system, and it’s working as it should. Again, sorry for the inconvenience; the issue was related to an update not related to us.
