Hello!
In unit 10 the exercise complete solution is not provided(btn_subscriber_scan.js is not given). I tried to solve exercise 10.2 but after pressing connect button i am unable to get the mentioned result.
see file (btn_subscriber_scan.js)
// Connecting to ROS
let ros
let btnConnect, btnCircles, btnAhead, btnStop, btnReadLaser
let txtRosbridgeAddress
let msgError
let spanMax, spanMin, spanMean
let laserScanSubscriber
const connect = (e) => {
e.preventDefault()
console.log(txtRosbridgeAddress.value)
try {
ros = new ROSLIB.Ros({
url: txtRosbridgeAddress.value
} catch (ex) {
evalState(2, ‘Check if you entered a valid address’)
ros.on(‘connection’, function () {
console.log(‘Connected to websocket server.’);
evalState(1)
setupSubscriber()
ros.on(‘error’, function (error) {
evalState(2, error)
console.log('Error connecting to websocket server: ', error);
ros.on(‘close’, function () {
evalState(0)
console.log(‘Connection to websocket server closed.’);
const evalState = (state, err = null) => {
if (state == 1) {
btnCircles.disabled = false
btnAhead.disabled = false
btnStop.disabled = false
msgError.innerHTML = ‘’
} else {
btnCircles.disabled = true
btnAhead.disabled = true
btnStop.disabled = true
spanMax.innerHTML = '-'
spanMin.innerHTML = '-'
spanMean.innerHTML = '-'
if (state == 2) {
msgError.innerHTML = err
const circles = (e) => {
e.preventDefault()
sendTopicMsg(0.5, 0.5)
const ahead = (e) => {
e.preventDefault()
sendTopicMsg(0.3, 0)
const stop = (e) => {
e.preventDefault()
sendTopicMsg(0.0, 0)
const sendTopicMsg = (x, z) => {
var topic = new ROSLIB.Topic({
ros: ros,
messageType: ‘geometry_msgs/Twist’
var msg = new ROSLIB.Message({
linear: { x, y: 0, z: 0 },
angular: { x: 0, y: 0, z },
topic.publish(msg)
const setupSubscriber = () => {
laserScanSubscriber = new ROSLIB.Topic({
ros: ros,
messageType: ‘sensor_msgs/LaserScan’
laserScanSubscriber.subscribe((msg) => {
updateLaserValues(msg)
laserScanSubscriber.unsubscribe()
const updateLaserValues = (msg) => {
let maxAllowed = msg.range_max
let minAllowed = msg.range_min
let max = minAllowed, min = maxAllowed, mean = 0
console.log(minAllowed, maxAllowed)
const filteredArray = msg.ranges.filter(r => {
return (
r >= minAllowed &&
r <= maxAllowed &&
r != null
console.log(filteredArray.length)
for (range of filteredArray) {
if (range > max) max = range
if (range < min) min = range
// avoid division by zero if no value is valid
let divider = 1
if (filteredArray.length > 1) {
divider = filteredArray.length
mean = filteredArray.reduce((acc, range) => acc + range, 0) / divider
spanMin.innerHTML = min.toFixed(2)
spanMax.innerHTML = max.toFixed(2)
spanMean.innerHTML = mean.toFixed(2)
// set events
document.onreadystatechange = () => {
btnConnect = document.getElementById(‘btnConnect’)
btnCircles = document.getElementById(‘btnCircles’)
btnAhead = document.getElementById(‘btnAhead’)
btnStop = document.getElementById(‘btnStop’)
btnReadLaser = document.getElementById(‘btnReadLaser’)
txtRosbridgeAddress = document.getElementById('txt_rosbridge_address')
msgError = document.getElementById('msg_error')
spanMax = document.getElementById('maximum')
spanMin = document.getElementById('minimum')
spanMean = document.getElementById('mean')
evalState(0)
if (document.readyState == 'complete') {
btnConnect.onclick = connect
btnCircles.onclick = circles
btnAhead.onclick = ahead
btnStop.onclick = stop
btnReadLaser.onclick = (e) => {
e.preventDefault()
setupSubscriber()
