In exercise 53 in unit 5, we’re told to compare MultiThreadedExecutor, SingleThreadedExecutor but when I copy the code, the rotate function is still the only thing that prints to std during its execution, I would have thought to see the other callbacks print too, what am I missing?
Hello @dumbkreate ,
Yes, when using the MultiThreaded Executor you should see all callbacks being executed. Can you paste here the whole code you are using?
