i killed a program in a terminal and it no longer has the green user:/ at the start of the line. it is completely blank at the start of the line. How do it get this back?
Hi @r.franklinismail ,
if you killed the terminal, you could just open a different unit that contains a different simulation. That would force the terminals to restart.
You could then go back to the Unit you were before.
