I was working on the Developing Web Interfaces for ROS series and came across this error:
Uncaught TypeError: Vue is not a constructor
here is my screenshot:
Any help would be appreciated.
Hi @ata2151 ,
The vue library might not be loaded properly.
Could you share the content of your index.html file?
Hi @marco.nc.arruda ,
Thank you for the response. here is my index.html file as requested:
<head>
<!-- Bootstrap -->
<link rel="stylesheet" href="https://stackpath.bootstrapcdn.com/bootstrap/4.3.1/css/bootstrap.min.css" integrity="sha384-ggOyR0iXCbMQv3Xipma34MD+dH/1fQ784/j6cY/iJTQUOhcWr7x9JvoRxT2MZw1T"
crossorigin="anonymous">
<!-- ROS stuff -->
<script type="text/javascript" src="https://static.robotwebtools.org/EaselJS/current/easeljs.min.js">
</script>
<script type="text/javascript" src="https://static.robotwebtools.org/EventEmitter2/current/eventemitter2.min.js">
</script>
<script type="text/javascript" src="https://static.robotwebtools.org/roslibjs/current/roslib.min.js">
</script>
<script type="text/javascript" src="https://static.robotwebtools.org/ros2djs/current/ros2d.min.js">
</script>
<!-- Vuejs -->
<script src="https://cdn.jsdelivr.net/npm/vue">
</script>
</head>
<body>
<div id="app" class="container">
<div class="row">
<div class="col-md-12 col-sm-6 text-center">
<h3>Connection status</h3>
<p class="text-danger" v-if="!connected">Not connected!</p>
<p class="text-success" v-if="connected">Connected!</p>
<label>ROSBridge address</label>
<br>
<input type="text" v-model="rosbridge_address" />
<br><br>
<button :disabled="loading" class="btn btn-danger" @click="disconnect"
v-if="connected">Disconnect!</button>
<button :disabled="loading" class="btn btn-success" @click="connect" v-else>Connect!</button>
</div>
<div class="col-md-12 col-sm-6" style="overflow:auto;">
<div class="row">
<div class="col-md-12 text-center">
<h5>Action client data</h5>
<div>
<label>Goal</label>
<div>
<label>X</label>
<input type="number" v-model.number="action.goal.position.x" />
</div>
<div>
<label>Y</label>
<input type="number" v-model.number="action.goal.position.y" />
</div>
<button :disabled="!connected || action.status.status == 1" @click="sendGoal">Start</button>
<button :disabled="!connected || ![1].includes(action.status.status)" @click="cancelGoal">Cancel</button>
</div>
<hr />
<div>
<label class="text-muted">Feedback</label>
<p>Position: {{ action.feedback.position }}</p>
<p>State: {{ action.feedback.state }}</p>
</div>
<hr />
<div>
<label class="text-muted">Result</label>
<p>Succeeded? {{ action.result.success }}</p>
</div>
<hr />
<div>
<label class="text-muted">Status</label>
<p>{{ action.status.text }}</p>
</div>
</div>
</div>
</div>
</div>
</div>
<script type="text/javascript" src="main.js">
</script>
</body>
</html>
Note that the problem started after unit_05 of the course where we are asked to display the camera on the website. The problem persists in unit_12, this is the problem I have posted here.
Hi @ata2151 ,
Thank you for sharing, the issue is that Vue latest library has been updated, so we need to specify the version in the script tag
Please, replace the tag
<script src="https://cdn.jsdelivr.net/npm/vue"></script>
By
<script src="https://cdn.jsdelivr.net/npm/vue@2.6.14/dist/vue.min.js"></script>
We are updating it in the notebooks in the meantime.
Please, let me know if that works for you
This topic was automatically closed after 23 hours. New replies are no longer allowed.
