Any help will be much appreciated, I keep getting the result below but the service is available in the service list. The service is ‘find_wall’.
user:~$ ros2 service call /find_wall std_srvs/Empty '{}'
waiting for service to become available...
user:~$ ros2 service list
/apply_joint_effort
/apply_link_wrench
/clear_joint_efforts
/clear_link_wrenches
/delete_entity
/find_wall
Thanks in advance for the help.
Hi @stphnlght ,
Welcome to this Community!
I think your command is wrong. I believe the command should be as follows:
ros2 service call /find_wall std_srvs/srv/Empty '{}'
Try this and let me know if that worked for you.
Thanks for the help but I seem to fall in the same situation
user:~$ ros2 service call /find_wall std_srvs/srv/Empty '{}'
Any Help Please?
I would really appreciate, been stuck here for a while
Can you check that your service is still running in the terminal where you are running it. It could have crashed, for instance.
system
Closed
6
