What does this line do?
Professor, Below is the line from a launch file:
<rosparam file="$(find husky_navigation)/config/costmap_global_static.yaml" command="load" ns="global_costmap" unless="$(arg no_static_map)"/>
  1. What does rosparam do ?
  2. What’s the function of file, command, ns, unless, and if ?
  3. Are the names in the 2nd question fixed ?
Hi ,
  1. It loads all the parameters defined in that .yaml file into the ros parameter server, so that all the rosprogarms can access that data.
  2. file: you define which file to load, command: tell this node what to do ( this is something unique of this rosparam tag ), ns: namespace of the data, in case you want to set those parameters inside a namespace . Very useful when various robots have the same names in the parameters.
  3. Most of them, in this example yes, because the navigation system expects those values.
What about unless and if, Professor Miguel @duckfrost ?
