Hello there, In order to learn SLAM, which courses do i need to do. Thanks
Hello @navjotsinghsodhi52 ,
To learn to apply SLAM with ROS, you can go with the ROS Navigation course (or ROS2 Navigation if you want to go with ROS2). If you want to learn the theoretical concepts behind SLAM, then this is not fully covered in our courses.
