I do not understand why is it necessary to use get_laser_summit() function inside a function. I looked into the source file and observed that both the functions are subscribed to different topics but their function is similar. Can somebody please explain it in a little detail?
Hi @dhruvil9121999,
welcome to our community.
You are referring to this part of the code, am I right?
def get_laser_values(a,b,c):
r1 = robotcontrol.get_laser_summit(a)
r2 = robotcontrol.get_laser_summit(b)
r3 = robotcontrol.get_laser_summit(c)
The reason why we call get_laser_summit
instead of get_laser
is:
IMPORTANT NOTE: As you can see, we have introduced a new function called get_laser_summit(). This function works exactly the same as the get_laser() function, but it is prepared to work with the Summit XL simulation (because the laser topics have different names).
But I see your point, we could just pass a parameter to the get_laser
function specifying the topic to subscribe to.
Please let us know in case you have further questions.
