Why is rosdep failing?
user:~/ros2_ws$ rosdep install -i --from-path src --rosdistro $ROS_DISTRO -y
executing command [sudo -H apt-get install -y ros-jazzy-backward-ros]
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
E: Unable to locate package ros-jazzy-backward-ros
ERROR: the following rosdeps failed to install
apt: command [sudo -H apt-get install -y ros-jazzy-backward-ros] failed
the same output even after sudo apt-get update and rosdep update.
I’am using ros2 jazzy.
  • List item
This is what is failing. Google it to find out how to solve it.
Here’s a link that might answer your question:
