Why is there an error message on both From messages in setup.py the file will not pass compile
Hi @ROxX,
You have to use the code below instead of “from os”:
import os
Another option would be:
from os import path
but then your os.path.join(... code would have to be changed to:
path.join(...
#KeepPushingYourROSLearning.
