Wrong name on Certificate - Code Foundation for ROS
Hi. I used my Git hub profile to register on Construct. May you please regenerate my Certificate with my actual name?
Ray Kanyepi
We have regenerated the certificate with the name on your profile.
Please note that we cannot set the name manually - the system automatically takes the name on the profile.
For security reasons, changing the name on the profile will NOT change the name on the certificate once it is generated. The user would need to contact us to reset the certificate as you have done.
thank you. much appreciated.
