Wrong rvec values- aruco marker ,open_Cv. the marker has actual rotation 0,0,0 whereas code returns -1.9,-1.9,-0.5
def image_callback(msg):
try:
rospy.wait_for_service(‘/gazebo/set_model_state’)
set_model_state = rospy.ServiceProxy(‘/gazebo/set_model_state’, SetModelState)
drone_model_state = ModelState()
drone_model_state.model_name = ‘drone_model’ # ‘’ for global frame
drone_model_state.pose.position.z = 4
drone_model_state.pose.position.x = 8.0
drone_model_state.twist = Twist()
drone_model_state.twist.linear.x = 0 # Maintain current velocity in x direction
drone_model_state.twist.linear.y = 0 # Maintain current velocity in y direction
drone_model_state.twist.linear.z = 0
    cv_image = bridge.imgmsg_to_cv2(msg, "bgr8")
    resized_image = cv2.resize(cv_image, (400, 400))
    gray = cv2.cvtColor(resized_image, cv2.COLOR_BGR2GRAY)
    corners, ids, _ = aruco.detectMarkers(gray, aruco_dict, parameters=parameters)
    rospy.loginfo(ids)
    if ids is not None:
        #cv2.imshow('Aruco Marker Pose', cv_image)
        aruco.drawDetectedMarkers(gray, corners, borderColor=(0, 165, 100))
        # Estimate pose of each marker
        rvecs, tvecs, _ = aruco.estimatePoseSingleMarkers(corners, marker_size, k, distortion_coefficients)
        idx = np.where(ids == marker_id)[0][0]
        rvec = normalize_rvec(rvecs[idx].flatten())
        rospy.loginfo(f"Normalized rvec: {rvec}")
        R, _ = cv2.Rodrigues(rvec)
        rospy.loginfo(f"Rotation Matrix (R):\n{R}")
        # Apply axis transformation to match world frame
        R_transformed = apply_axis_transformation(R)
        # Convert the transformed rotation matrix to a quaternion
        qw, qx, qy, qz = rotation_matrix_to_quaternion(R_transformed)
        # Print the pose of the detected marker
        if ids == marker_id:
            rospy.loginfo(f"Marker ID: {marker_id}")
        rospy.loginfo(f"Quaternion (qx, qy, qz, qw): {qx}, {qy}, {qz}, {qw}")
        drone_model_state.pose.orientation.x = 0
        drone_model_state.pose.orientation.y = qy
        drone_model_state.pose.orientation.z = 0
        drone_model_state.pose.orientation.w = 1
    elif ids is None:
        rospy.loginfo("Marker not detected")
    set_model_state(drone_model_state)
    ids=None
    R=np.empty((3, 3))
except Exception as e:
    rospy.logerr(f"Error processing image: {e}")
return
@soumildev26
Please give some background information so that someone can help you. Here are some suggestions:
  • Which course and/or rosject are you working on?
  • What is working?
  • What is not working?
  • Give full text of error message
  • Share a full screenshot of the error.
  • What is the code you have shared, on which line is the error occurring?
