6.4 Services Quiz
I am getting an error constantly for the quiz
please guide me through this
indent preformatted text by 4 spaces
from my_custom_srv_msg_pkg.srv import BB8CustomServiceMessage, BB8CustomServiceMessageResponse
def my_callback(request):
rospy.loginfo("The Service move_bb8_in_square_custom has been called")
i = 0
while  i <=request.repetitions:
    move_square.linear.x = 1*request.size
    move_square.angular.z = 1.57
    move_sqaure.angular.y = 1*request.size
    move_ssquare.angular.z = 1.57
    my_pub.publish(move_square)
rospy.loginfo("Finished service move_bb8_in_square_custom")
response = BB8CustomServiceMessageResponse()
response.success = True
return response # the service Response class, in this case EmptyResponse
rospy.init_node(‘service_move_bb8_in_square_custom_server’)
my_service = rospy.Service(’/move_bb8_in_square_custom’, BB8CustomServiceMessage , my_callback) # create the Service called move_bb8_in_circle with the defined callback
my_pub = rospy.Publisher(’/cmd_vel’, Twist, queue_size=1)
move_circle = Twist()
rate = rospy.Rate(1)
rospy.loginfo(“Service /move_bb8_in_square_custom Ready”)
rospy.spin() # mantain the service open.
Hello @Ankit_Kumar ,
Well, the error is clearly in this line
Apparently, your script is not able to do this import. Have you properly compiled this message in the my_custom_srv_msg_pkg package? In case you have done so, have you added this package as a dependency of the services_quiz package?
In any case, I’d suggest you create this custom message BB8CustomServiceMessage in the services_quiz package (instead of the my_custom_srv_msg_pkg package), as it is requested by the Quiz.
I tried creating BB8CustomServiceMessage in the services_quiz package. However, when I am running catkin_make it’s giving me this error.
I am using this file that you can download from -
https://i-030fb78b28a2e01e4.robotigniteacademy.com/39d681d8-df7f-422b-b814-28b26e738912/files/download/?id=6791512a-e6b7-47ae-b922-4bf4203fd190
I’ve done some modifications that should fix this error you showed in the image.
I tried everything yet I this error is coming. Please guide me through this it’s being more than two weeks I am struck at this. I might be doing wrong in Cmake and pakage.xml
here’s the download link
https://i-01bfc8d0c01bf3c90.robotigniteacademy.com/ff56753b-4488-4ca2-a116-a8f2ca0db650/files/download/?id=59c3384e-8645-41a7-8496-d480656c96af
This line of code
from my_custom_srv.srv import BB8CustomServiceMessage, BB8CustomServiceMessageRequest
says that you have a package named my_custom_srv where you have created the custom service message. From what the error is saying (No module named ‘my_custom_srv’) and what I can see in your screenshot, it looks like you don’t have this package.
