I am following the course ROS2 Navigation, on section 2 which was creating map. I had an error stated “Failed processing YAML file /home/user/ros2_ws/install/project_mapping/share/project_mapping/maps/turtlebot_area.yaml at position (-1:-1) for reason: bad file”
The file looks correct @AlfoChri . That’s really strange… my only suggestion would be to try to generate the map once again. If you are still getting the same error after that, let me know and I will check directly into your file to see what’s going on.
