When executing the command plan and execute from the home variable within the Query of the planning aspect of the robot I get the error that it failed to plan and execute the motion
[move_group-1] You can start planning now!
[move_group-1]
[move_group-1] [INFO] [1708460794.637767640] [moveit_move_group_default_capabilities.move_action_capability]: Received request
[move_group-1] [INFO] [1708460794.638015609] [moveit_move_group_default_capabilities.move_action_capability]: executing…
[move_group-1] [INFO] [1708460795.638185887] [moveit_ros.current_state_monitor]: Didn’t received robot state (joint angles) with recent timestamp within 1.000000 seconds.
[move_group-1] Check clock synchronization if your are running ROS across multiple machines!
[move_group-1] [WARN] [1708460795.638249335] [moveit_ros.planning_scene_monitor.planning_scene_monitor]:Failed to fetch current robot state.
[move_group-1] [INFO] [1708460795.638326622]
Nvm it is expected my apologies
