Good day, I started having the above error after upgrading the course to ROS2 Humble as was suggested and it has gotten me completely stuck. Can any one help? Where is this error coming from … How do I fix it?
The problem was that you still had many packages from the old version of the course. When you migrate it you should remove all the old packages and build again your workspace, as indicated in the migration notes:
Because of all these updates, the old material of the course is deprecated and will not work with the new version of the course. Therefore, you must remove all the packages and files created in the old version of the course.
I’ve removed some of the old packages you had (not all of them, but you should), rebuilt the workspace, and now everything is working fine.
