I am doing the ROS control course and am about to create a controller.
In the torturial, I’m supposed to update the package.xml with the following, before doing a catkin_make:
<controller_interface plugin="${prefix}/controller_plugins.xml"/>
inside the tag.
I get an error and I’m confused about the low amount of pointers, regarding how to set up the package.xml.
I have uploaded an image of the error I receive when I use catkin_make. You can see where I’ve placed the snippet in my package.xml on the image.
Maybe the placement is completely wrong.
Please put that line after the <export> tag before the closing </export> tag.
Here is the complete package.xml file. Please compare your package.xml with this one.
<?xml version="1.0"?>
<package format="2">
<name>my_controller</name>
<version>0.0.0</version>
<description>The my_controller package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<license>TODO</license>
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/my_controller</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<build_depend>controller_interface</build_depend>
<build_depend>hardware_interface</build_depend>
<build_depend>pluginlib</build_depend>
<build_export_depend>controller_interface</build_export_depend>
<build_export_depend>hardware_interface</build_export_depend>
<build_export_depend>pluginlib</build_export_depend>
<build_export_depend>roscpp</build_export_depend>
<exec_depend>controller_interface</exec_depend>
<exec_depend>hardware_interface</exec_depend>
<exec_depend>pluginlib</exec_depend>
<export>
</export>
</package>
