Can't load custom controller
Hi, I have a problem in quiz 2.
I’m working on local in a virtual machine because it seems that the my simulation environment for the quiz does’t work.
I have spawned my robot with success for the part 1.
Now when it comes to the part 2 I’m facing the following problem when I launch:
Could not load controller 'joint2_position_controller' because controller type 'project_controller/PositionController' does not exist.
[ERROR] [1668903995.359815020, 0.186000000]: Use 'rosservice call controller_manager/list_controller_types' to get the available types
follow the code:
custom_controller.cpp
#include <controller_interface/controller.h>
#include <hardware_interface/joint_command_interface.h>
#include <pluginlib/class_list_macros.h>
namespace controller_ns {
class PositionController : public controller_interface::Controller<
                               hardware_interface::EffortJointInterface> {
public:
  bool init(hardware_interface::EffortJointInterface *hw, ros::NodeHandle &n) {
    std::string my_joint;
    if (!n.getParam("joint", my_joint)) {
      ROS_ERROR("Could not find joint name");
      return false;
    joint_ = hw->getHandle(my_joint); // throws on failure
    return true;
  void update(const ros::Time &time, const ros::Duration &period) {
    double error = setpoint_ - joint_.getPosition();
    joint_.setCommand(error * gain_);
  void starting(const ros::Time &time) {}
  void stopping(const ros::Time &time) {}
private:
  hardware_interface::JointHandle joint_;
  static constexpr double gain_ = 2.25;
  static constexpr double setpoint_ = 1.00;
PLUGINLIB_EXPORT_CLASS(controller_ns::PositionController,
                       controller_interface::ControllerBase);
} // namespace controller_ns
plugin file
<?xml version="1.0"?>
<library path="lib/libmy_controller_lib">
  <class name="project_controller/PositionController"
         type="controller_ns::PositionController"
         base_class_type="controller_interface::ControllerBase" />
</library>
ur5_controller_custom.yaml
ur5:
  joint_state_controller:
    type: joint_state_controller/JointStateController
    publish_rate: 50
  joint1_position_controller:
    type: position_controllers/JointPositionController
    joint: shoulder_pan_joint
    pid: {p: 10.0, i: 0.01, d: 10.0}
  joint2_position_controller:
    type: project_controller/PositionController
    joint: shoulder_lift_joint
  joint3_position_controller:
    joint: elbow_joint
  joint4_position_controller:
    joint: wrist_1_joint
  joint5_position_controller:
    joint: wrist_2_joint
  joint6_position_controller:
    joint: wrist_3_joint
quiz_control_custom.launch
<launch>
  <include file="$(find gazebo_ros)/launch/empty_world.launch">
        <!-- <arg name="world_name" value="worlds/mud.world"/> -->
  </include>
  <group ns = "/ur5">
    <rosparam command = "load" file = "$(find project_controller)/config/ur5_controller_custom.yaml" />
    <param name = "robot_description" command = "$(find xacro)/xacro --inorder '$(find project_controller)/urdf/ur5_robot.urdf.xacro'" />
    <arg name = "x" default = "0" />
    <arg name = "y" default = "0" />
    <arg name = "z" default = "0.5" />
    <!-- spawn the robot in the world  -->
    <node name = "mybot_spawn" pkg = "gazebo_ros" type = "spawn_model" output = "screen"
      args = "-urdf -param robot_description -model ur5_robot -x $(arg x) -y $(arg y) -z $(arg z)" />
    <node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
      output="screen" ns = "/ur5" args="--namespace=/ur5
                                        --timeout 60"/>
    <node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher"
      respawn="false" output="screen">
      <remap from="/joint_states" to="/ur5/joint_states" />
    </node>
    <!-- rqt spawner-->
    <node name = "rqt_reconfigure" pkg = "rqt_reconfigure" type = "rqt_reconfigure" />
    <node name = "rqt_publisher" pkg = "rqt_publisher" type = "rqt_publisher" />
  </group>
</launch>
Could anyone tell me what I’m doing wrong?
I have updated package.xml and CMakeLists.txt accordly
Thank you
Hi @Francesco_Rizzotti,
one possible cause is that ROS can’t find the package with your custom controller. Have you build your workspace and sourced all terminals where you execute your launch files?
Additionally could you please paste the content of your CMakeLists.txt and package.xml files here?
Cheers,
Roberto
Hi @rzegers , thank you for your reply.
Every joint works, exept the joint2_position_controller: in config file as follows:
The package for the quiz2 is in the same workspace of the quiz1.
I have source the code in my ws with source devel/setup.bash and build the package.xml with catkin_make
her my package file:
<package format="2">
  <name>project_controller</name>
  <version>0.0.0</version>
  <description>The project_controller package</description>
  <!-- Example:  -->
  <maintainer email="ros@todo.todo">ros</maintainer>
  <!--   BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
  <license>TODO</license>
  <!-- Example: -->
  <!-- <url type="website">http://wiki.ros.org/project_controller</url> -->
  <!-- Example: -->
  <!-- Examples: -->
  <!--   <depend>roscpp</depend> -->
  <!--   Note that this is equivalent to the following: -->
  <!--   <build_depend>roscpp</build_depend> -->
  <!--   <exec_depend>roscpp</exec_depend> -->
  <!--   <build_depend>message_generation</build_depend> -->
  <!--   <build_export_depend>message_generation</build_export_depend> -->
  <!--   <buildtool_depend>catkin</buildtool_depend> -->
  <!--   <exec_depend>message_runtime</exec_depend> -->
  <!--   <test_depend>gtest</test_depend> -->
  <!--   <doc_depend>doxygen</doc_depend> -->
  <build_depend>controller_interface</build_depend>
  <build_depend>hardware_interface</build_depend>
  <build_depend>pluginlib</build_depend>
  <build_export_depend>controller_interface</build_export_depend>
  <build_export_depend>hardware_interface</build_export_depend>
  <build_export_depend>pluginlib</build_export_depend>
  <build_export_depend>roscpp</build_export_depend>
  <exec_depend>controller_interface</exec_depend>
  <exec_depend>hardware_interface</exec_depend>
  <exec_depend>pluginlib</exec_depend>
  <export>
    <controller_interface plugin="${prefix}/custom_controller_plugins.xml"/>
  </export>
</package>
and here my CMa[keLists.txt
project(project_controller)
hardware_interface
pluginlib
roscpp
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
# generate_messages(
# DEPENDENCIES
# std_msgs # Or other packages containing msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES project_controller
# CATKIN_DEPENDS controller_interface hardware_interface pluginlib roscpp
# DEPENDS system_lib
## Build ##
include_directories(
include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/project_controller.cpp
add_library(my_controller_lib src/custom_controller.cpp)
target_link_libraries(my_controller_lib ${catkin_LIBRARIES})
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/project_controller_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_project_controller.cpp)
# endif()
# catkin_add_nosetests(test)
Furthermore, my account on the construct seems to not loading the simulation environment.
Is it possible to check it out?
Thank you
Francesco
good morning @rzegers
do you have any update about that? I’m stucked in to figure it out what’s going on…
Hello @Francesco_Rizzotti,
I am checking throught the unit and verifying that you haven’t missed any step and that everything is properly implemented in the code. One of the checks is to verify that the filenames match with the code, for instance what is the name for the XML plugin file that you are using? Please post it here so that I can check against what is inside the tags inside the package.xml file.
Also, very important as part of the debugging, please post the output of the command shown below since it will tell us if the controller was installed successfully.
rospack plugins --attrib=plugin controller_interface
Cheers,
Roberto
I have loaded Unit 7 and the simulation takes a while to load, but then it’s ok.
Could you please provide a screenshot of how your simulation environment on “The Construct” looks like?
This is a screenshot of how the unit and simulation looks like at my end:
Roberto
You can try replacing my_controller with project_controller in your CMakeLists.txt and plugin file. In Chapter 4 the package name was my_controller but in the quiz is project_controller.
Cheers,
Jose
