I have been trying to add a RFID package from the website:
RFIDsensor_Gazebo_plugin - ROS Wiki .
Once I clone the package and try to rebuild the the workspace using catkin_make, I get an error like this:
I tried renaming it to lowercase but received the same error.
Can anybody help me?
Hi @mamojiz97 ,
I guess your package is dependent on mavros_msgs. So just download/install mavros_msgs.
It should be quite simple command: sudo apt install ros-noetic-mavros-msgs.
Once mavros_msgs is installed, add mavros_msgs as your package dependency in CMakeLists.txt and package.xml.
Let me know if this fixed your issue.
Hey @girishkumar.kannan
Thanks for replying.
I did as you asked and couldnt solve the issue still.
project(RFID_tag_plugin)
set(CMAKE_PREFIX_PATH _PATH "/opt/ros/melodic;${CMAKE_MODULE_PATH}")
# add_subdirectory(third_party/yaml-cpp)
gazebo_msgs
geometry_msgs
tf2_ros
mavros_msgs
roscpp
roslib
rospy
sensor_msgs
std_msgs
find_package(gazebo REQUIRED)
if(YAMLCPP_STATIC_LIBRARY)
set(YAMLCPP_STATIC libyaml-cpp.a)
endif()
generate_messages(
DEPENDENCIES
std_msgs mavros_msgs # Or other packages containing msgs
catkin_package(
INCLUDE_DIRS include
LIBRARIES RFID_tag_plugin
CATKIN_DEPENDS roscpp rospy mavros_msgs
DEPENDS system_lib
include_directories(
# include
${catkin_INCLUDE_DIRS}
${GAZEBO_INCLUDE_DIRS}
## Declare a C++ library
add_library(RFID_tag_plugin src/tags.cpp)
target_link_libraries(RFID_tag_plugin
${catkin_LIBRARIES}
${GAZEBO_LIBRARIES}
yaml-cpp
The above is cmakeLists.text.
<build_depend>gazebo_msgs</build_depend>
<build_depend>geometry_msgs</build_depend>
<build_depend>mavros_msgs</build_depend>
<build_depend>roscpp</build_depend>
<build_depend>roslib</build_depend>
<build_depend>sensor_msgs</build_depend>
<build_export_depend>gazebo_msgs</build_export_depend>
<build_export_depend>geometry_msgs</build_export_depend>
<build_export_depend>mavros_msgs</build_export_depend>
<build_export_depend>roscpp</build_export_depend>
<build_export_depend>roslib</build_export_depend>
<build_export_depend>sensor_msgs</build_export_depend>
<exec_depend>gazebo_msgs</exec_depend>
<exec_depend>geometry_msgs</exec_depend>
<exec_depend>mavros_msgs</exec_depend>
<exec_depend>roscpp</exec_depend>
<exec_depend>roslib</exec_depend>
<exec_depend>sensor_msgs</exec_depend>
The above is the package.xml
I receive this error:
Hi @mamojiz97 ,
I think you need to install the complete mavros packages.
Use this command: sudo apt install ros-noetic-mavros* [Note the asterisk sign at the end].
This will install all mavros dependent packages.
Then try compiling again and let me know if you still get the same errors.
Hi @girishkumar.kannan
I did like you asked and I still receive the exact same error.
I believe the problem here is that the RFID package that I am cloning is compatible with ROS Melodic and not ROS Noetic.
On ROS wiki page for the package it does say its compatible to ROS Melodic .
Could I use the same for ROS Noetic?
I moved my project to ROS Melodic and added the plugin/package and it worked.
I still want to know if its possible to make use of the package in ROS Noetic etc and how?
Hi @mamojiz97 ,
Glad to know that you have fixed your problem (by changing ROS versions).
To switch your project from Melodic to Noetic you need to first go through the contents of the package. It depends on the package and all the files. And wherever you find references to Melodic you will have to replace those with Noetic instances.
The best thing to do is to find the same (or similar package) for Noetic version. Porting a Melodic package to Noetic could become time-consuming. It also requires library-level deep knowledge in ROS which is suitable for advanced users who can understand ROS architecture good enough.
You can give it a try (porting versions), but I recommend you to find a Noetic package.
system
Closed
July 17, 2023, 5:09am
8
